More Options for MIDI Conversion
  • Dr. Mack Foxx
    • Feb 2007
    The ability to convert MIDI to digital audio through dBpowerAMP Music Converter is nice, but I wish there was a way to render out the audio using different Software or Hardware Wavetable Synthesizers, such as Yamaha XG or Wingroove. The Microsoft GS, Roland or whatever synthesizer is built into the MIDI decoder does work, but it just doesn't cut it for MIDIs made using more advanced systems (IE: Yamaha.) I would like the MIDI decoder to be able to work with any installed wavetable synthesizer.
    Re: More Options for MIDI Conversion
    From the MIDI help file:
    DLS SoundFonts
    This Midi renderer automatically loads the sound set \<Windows>\<System32>\Drivers\GM.DLS should a different (possibly better .DLS file be required, overwrite the existing GM.DLS file with newer).
