dMC & LARGE fonts
    dMC & LARGE fonts
    Hi!
    There is one big problem! Try to use dMC while having large fonts in Windows (res 1024x768) . It (main program form) looks horrible! Labels are cut, other components seem to be moved, in one word: total mess!
    If it's written in Delphi/Builder I know the solution!
    Good luck! And keep developing this excelent program (and mind these fonts! )
    Regards,
    Luke
    • 46218
    It is down to be done, sometime in the future.
    • steveg
      I'd support Luke on this.
      The comment in the FAQs that large fonts are for the 'visually impaired' is ridiculous. (Unless you assume that everyone over the age of 40 who wears glasses is visually impaired!!)
      Please keep it near the top of your 'To Do' list!
      Many thanks
      Steve
        I have the same problem
        Buttons get burried under other stuff because of large fonts not fitting. You CAN'T work with normal fonts on a modern 1600x1200 screen!
          This would be a good thing.
