Multi-encoder, add your art while ripping, transfering album art
  • wolf333
    • Mar 2005
    I've been playing around with r12 reference for a few hours tonight and I like it over-all. There are a few things I have noticed -
    - For albums that have no art on AMG, it would be nice if you could import your own art into cdripper before ripping.
    - When converting from FLAC to mp3, the album art does not transfer. I've tried adding to each file separately and also using Tag&Rename, but no luck. I understand that the tag format is different between different codecs, but maybe adding the option to use the existing folder.jpg might work.
    - Finally, I've seen the question asked in another thread, but is there a plan to add a multi-encoder (encoding to multiple formats at once) in the future? That was one of the best features in previous versions.
    Thanks for all of you work Spoon.
    Re: Multi-encoder, add your art while ripping, transfering album art
    For your third question, I believe the Multi-Encoder is being ported over, yes.
    The first question may make it into the next r12 update or may be pushed back to r13, more likely the last.
    As for transferring album art, Spoon will have to answer this one.
      • 46159
      Our FLAC implementation is missing the new album art (it will take it from id3v2 if there), will be updated when we can.
