Skin Designer Possible Enhancements
  • Narler
    • 74
    Hi Spoon,
    Just been working on my new skin and there's a few little things which I thought would make the Skin Designer a little more flexible with 2 Component options:
    • With Buttons , there are 3 options. SET, CLEAR and TOGGLE. What I've noticed is if i configure a button to SET, it does indeed set whatever I configure in the Events section, however it does NOT remain in the set Image (as set by Mouse Down Image) ? Instead it returns to the Normal Image?.
      Is there any reason, why the button will not stay in the set position, until this Event is cleared by a button configured to CLEAR this Event?
    • Looking at the Images option is there any possibility of having that a little more flexible?.. For instance instead of just limiting it to Stereo or Mono options, can the "Show While" option be configured to use USER commands, or be use for other default options such as "evtdBEqOn". Basically it would be cool if the Images "Show While" option was as flexible as the Events option for buttons (minus the onclick option though).
    Anyways that's just some thoughts.
    cya
