Select Avg Bitrate when using Lame ABR
    When using Lame ABR in DMC you have to select the min and max bitrate. However, when using other encoding programs you just select the avg bitrate and encode. You only have to select the mix and max for VBR. It would make it easier for me to encode with ABR if I only had to select the avg bitrate instead of picking mins and max. (Please add this option to the alt ABR presets as well)
  • Joseph
    • Oct 2002
    • 211
    Re: Select Avg Bitrate when using Lame ABR
    I also noticed that because when I encode files for my Rio 500 I like to keep them at Lame 3.93(VBR Fixes ect) ABR set to 80 from the range of 32 - 256
    -Joseph
    - Joseph
    • MODatic
      • 230
      This has been fixed in the latest beta of dMC.
      Cheers,
      [color=Blue][b]MODatic[/b][/color] :)
      [url=http://www.modatic.net/]modatic.net[/url]
      • Joseph
        • Oct 2002
        • 211
        That's good.
        Do you know when it will be avalible?
        - Joseph
        • MODatic
          • 230
          It's a fix (a significant one in my eyes ) that made it into dMC R10 beta 2 which is readily available from here.
          Do you mean the official release of R10? I would imagine that's a fair way down the track as that's a fairly early beta. (usually there are 4-5 betas before a proper release.)
          Cheers,
          • Joseph
            • Oct 2002
            • 211
            ok. THANKS A LOT! for the link.
            - Joseph
              Yes, thanks for the link. Can't wait until the next dMc release :happy:
