Message when encountering problem in flac-files
  • Tigerman
    • Mar 2005
    • 157
    I don't know if this is asked before, but I would like receive a message if DBpoweramp encounters a problem when encoding flac files.
    p.e. I have downloaded an incomplete flac-file. In Winamp I get the message "error while processing frame...." Dbpoweramp converts the file up to the point were it encounters the problem but does not give a warning.
    This results in a converted files with only a part of the original without me knowing about it. Very annoying
    I would like a message like the one I receive when I try to convert a corrupt ape-file.
    "Happiness is nothing more than good health and a bad memory."
    Albert Schweitzer (1875 - 1965)
    Re: Message when encountering problem in flac-files
    The dMC r12 alpha has a FLAC codec that has an option to verify the encoded audio. From its help file:
    After Encoding Verify Written Audio once compression is complete the compressed audio will be read and compared to the source, verifying the compression is without error (hard disk, or very unlikely codec induced).
    Is this what you are wanting?
      The decoder also has various options for verifying flac decoding, such as comparing against the md5, this is for Music converter r12.
      • Tigerman
        • Mar 2005
        • 157
        I made a mistake in my first post. I ment a message if dbpoweramp encounters a problem in a flac-file while decoding to p.e. wav or mp3.
        If I understand Spoon correctly it will be in r12?
        But verifying a by dbpoweramp encoded flacfile is also welcome
          Aha, there it is. There is an option in dMC r12's Configuration about errors on decode. You can either stop decoding on an error or continue decoding but show there was an error.
