Discussion of dMC R12 Alpha
This topic is closed.
    • 46220
    #121
    Re: Discussion of dMC R12 Alpha
    They are case sensitive. The command prompt cannot be shown. Your command line would not work if something had a space in it (the filenames will not as short names are used), ie:
    c:\temp.wav c:\a.mp3 an artist an album a title...
    You need quotes around the items?
    • kwanbis
      • Mar 2006
      • 45
      #122
      thanks spoon. Yes, the problem was when MAREO logged to thescreen (witch is a simple delphi call to write("text").
      I had to modify MAREO, so i can tell it not to log to screen.
      why should i pay attention to write [album], instead of [Album]?
      as i said, i fixed the problem, but i rather see the command prompt running, that not knowing what is happening.
      Your command line would not work if something had a space in it (the filenames will not as short names are used)... You need quotes around the items?
      Right, good point.
      For anyone interested, here is how to setup MAREO with dbpoweramp beta: http://www.hydrogenaudio.org/forums/...dpost&p=431475
      • kwanbis
        • Mar 2006
        • 45
        #123
        once dbpamp estarts ripping, there is no way to cancel! I have to press ALT-F4, to do it. Also, it looks like dbpamp is not "listening" to the errorlevel of the encoder.
          #124
          If your using "Rip to RAM", then the rip is not canceled until the current track is finished ripping.
          Also, what do you mean "error level of the encoder"?
          • kwanbis
            • Mar 2006
            • 45
            #125
            what is rip to RAM? That my encoder was returning an errolevel of 1 (0 is all ok, more than 0 is error), and it ignores, and continues to rip.
              #126
              Rip to RAM is a PowerPack option in Audio CD Input. However, I can't seem to find if this option is in the beta right now.
              Also, another reason its pausing could be that it is trying to securely rip the track and doesn't stop until it succeeds.
                • 46220
                #127
                Rip to Ram is default in the new ripper, ah progress...
                Currently to cancel a rip click the rip button (again) and OK to the cancel message.
                  • 46220
                  #128
                  Looking at your screen shot you do not have Pass Wave Header checked (for the CLI Encoder), how does the encoder know what the frequency, channels etc is?
                  • kwanbis
                    • Mar 2006
                    • 45
                    #129
                    I don't know, but it is working .. :| ... you think i should leave it checked then?
                      • 46220
                      #130
                      Depends on mareo.
                      • kwanbis
                        • Mar 2006
                        • 45
                        #131
                        MAREO just calls multiple encoders, for example, i have it setup to call, FLAC first, to generate song.flac, then wavegain to gain the original wav, and then, it calls LAME to create song.mp3, from the wavegained original.
                        • EliC
                          • 1175
                          #132
                          Spoon, could you add a reporting of data from the new CD ripper to start building a db of average wav size and average number of errors in songs with errors? In reference to: This
                          • Vulcan
                            • Aug 2006
                            • 27
                            #133
                            Any idea when log files will be implemented spoon?
                              • 46220
                              #134
                              Going in now.
                                • 46220
                                #135
                                dBpowerAMP Release 12 Alpha 6
                                A significant update for CD Ripper, mainly:
                                AMG meta data
                                Album Art
                                Log files (3 levels of log)
                                Album Artist Tag
                                Meta Data ID Tag section, for removing & adding specific tags
                                C2 ripping enhancements
                                Prevent AutoRun Option (a low level catch of the new CD notification, no malware will install)
                                New 'naming' existing users click 'set' and 'default'
                                Preview of audio tracks
                                As well as:
                                FLAC encoder
                                Album Art supportted in most codecs
                                C2 enhancements include a best result from c2 if cannot match 10 frames, also it is recommended that if a drive supports c2 then the maximum re-reads should be set to around 700 (you will see impressive results with this).
