Right Click Menu's not appearing x64
  • Sir MMPD Radick
    • May 2005
    • 8
    Just thought you guys should know that the Right Click Menu's/Pop up tips/ Explorer ID Tag Propertys Pages do not seem to work on Windows XP x64.
    I did a quick search on x64 on the forums and did not come up with anything, I apologize if this has already been reported....
    Making mp3's though seems to be fine if you go through the program itself, I have not had any problems.
    Currently running DMC 11.1 RC1
    Re: Right Click Menu's not appearing x64
    Is that also enabled in the folder options for all folders in WIndows Explorer?
    • Sir MMPD Radick
      • May 2005
      • 8
      Yes, the pop up info is set for all folders in the folder options.
      Normal tooltips work fine.
      I have also tried unchecking and rechecking the box in the DMC program to see if that would fix it, no go there either.
      Also I have rebooted multiple times.
        Try a registry fix: http://www.winguides.com/registry/display.php/963/
        CAREFULLY!
        You may have disabled (knowingly or maybe it's a default) integrations into the Windows Shell.
        Or maybe this problem: http://geekswithblogs.net/bpaddock/a.../02/28023.aspx
        • Sir MMPD Radick
          • May 2005
          • 8
          Thank you for looking around, but the registry fix does not work.
          Also the .rar on the other link does not let me download. :|
          But, yes I am also having trouble with the context menus on WinRar.
          MP3 tag is about the only program that has successfully added anything to the right click menu.... :|
            Sorry, you'll need to do more googling on your own, since you have such a system and I don't so I can't figure out what to look for in any case.
            • Sir MMPD Radick
              • May 2005
              • 8
              Thank you for trying, it is much appriciated!
                For Win 64 bit any shell integration needs a 64 bit program, which dbpoweramp is not yet. This will be looked at over the coming months.
                • Sir MMPD Radick
                  • May 2005
                  • 8
                  cool! thx!
                  • ^KrS^
                    • Jun 2005
                    I fixed up that WinRar reg file from the post above so it works correctly, but i can't upload yet hehe.
