Another Issue With Double Quotes, R17.1 Beta 13 for macOS
  • AllenM
    • Jun 2020
    Came across another issue with double quotes. Using dynamic naming, [genre]/[album]/[disc] - [track] - [maxlength]128,[title][]. When double quotes are used, sometimes the metadata for a track will not be written. Change to single quotes (or no quotes) and the metadata does get written. Change back back to double quotes, no metadata.
    The bad behavior is not consistent. Ripped a CD this morning where all the track names had double quotes, the first three tracks had metadata, the last two tracks had none.
    Config tar is attached. Happy to provide debug logs...
    Super Moderator
    • 1559
    Re: Another Issue With Double Quotes, R17.1 Beta 13 for macOS
    Issue being investigated, thanks for reporting.
      Super Moderator
      • 1559
      Fixed in beta 14.
      • AllenM
        • Jun 2020
        PeterP,
        Beta 14 installed and tested OK.
        Thanks for the quick fix!
        --AllenM
