Asset UPnP R7
This topic is closed.
  • vilsen
    • Jul 2018
    • 223
    Re: Asset UPnP R7
    Thanks, no worries
    • offline
      • Feb 2012
      • 38
      Re: Asset UPnP R7
      Synology version coming out?
        • 46231
        Re: Asset UPnP R7
        At some point yes.
        • RLANE
          • May 2011
          • 138
          Re: Asset UPnP R7
          I tried BETA 2 several times yesterday.
          Each time it would scan the 25K FLAC and MP3 files in the folder I used for the test.
          But the Asset catalog would be empty, 0 tracks and 0 albums.
          When I dump the contents of the library using uMediaLibrary-dumpdb.exe, all that it has is album cover meta data.
          For the last attempt:
          1. Installed 6.2
          2. Successfully scanned the 25K files
          3. Copied all versions of the MediaDatabaseFields file (identical copies for v5, v6, and v7) to a backup folder
          4. Copied all versions of the AssetUPnPDefinedBrowseTree file (identical copies for v5, v6, and v7) to a backup folder
          5. Ran V. 7 BETA 2 installation, which first uninstalls 6.2
          6. After 6.2 uninstalled and computer rebooted I deleted allversions of uMediaLibraryMainDB*.bin file and all versions of ArtStore*.bin file
          7. Proceeded with completion of installation of V. 7 BETA 2
          8. Copied all versions of the MediaDatabaseFields file (identical copies for v5, v6, and v7) from the backup folder to the production folder
          9. Copied all versions of the AssetUPnPDefinedBrowseTree file (identical copies for v5, v6, and v7) from the backup folder to the production folder
          10. Restarted Asset
          11. Did a full scan
          Same results. Album cover meta data, no data for FLAC or MP3 when dumped - not even a header with the field names.
          Installation is on a Windows PC running 8.1 Pro.
          • vilsen
            • Jul 2018
            • 223
            Re: Asset UPnP R7
            Perhaps there's an error in MediaDatabaseFieldsv7.txt, if so you could get 0 tracks and 0 albums. Have you added anything in this file?
            Also, what do you mean by "identical copies for v5, v6, and v7"? I've never seen a v6, and v5/v7 is not compatible. So I hope you're not using MediaDatabaseFieldsv5.txt in R7 (if that's what you mean).
              • 46231
              #21
              Re: Asset UPnP R7
              Stop asset from running (control page), then delete everything in that uMediaLibrary folder, start asset, then change the path to your music library if you have to, then trigger a rescan.
              • RLANE
                • May 2011
                • 138
                #22
                Re: Asset UPnP R7
                The "v6" ones are non-operational - I think I just saved them to have documented what was in use then.
                Got it right now.
                Figured out how to define single-entity fields and multiple entity fields.
                Very happy!
                Nice job.
                • RLANE
                  • May 2011
                  • 138
                  #23
                  Re: Asset UPnP R7
                  Got it right now.
                  Very happy!
                  Nice job.
                  The only problem I have is with the "album artist" tag.
                  The values get scanned and parsed, but all of the containers below them are empty.
                  I have attached the browse tree and media files.
                    • 46231
                    #24
                    Re: Asset UPnP R7
                    Try as a test:
                    Album Artist / Album{_no_track_list_}{_a_to_z_}
                    Album Artist / Album\Album
                    does that work, if so then try:
                    Album Artist{_no_track_list_}{_a_to_z_}
                    Album Artist\Album
                    • RLANE
                      • May 2011
                      • 138
                      #25
                      Re: Asset UPnP R7
                      Try as a test:
                      Album Artist\Album
                      Same behavior.
                      I scanned just one item with 8 tracks (4 FLAC, 4 MP3).
                      Attached is the dump.
                      It looks like the indexes at the bottom have multiple items combined as t_artist (Artist, Album Artist, and Composer.)
                      Is that by design?
                      • RLANE
                        • May 2011
                        • 138
                        #26
                        Re: Asset UPnP R7
                        Same behavior.
                        Is that by design?
                        I loaded the same files in 6.2.
                        See same there with t_artist, so that is likely not the problem.
                        It is strictly with browsing "Album Artist".
                          • 46231
                          #27
                          Re: Asset UPnP R7
                          Updated to beta 3:
                          bug fix: album artist listing now works
                          • vilsen
                            • Jul 2018
                            • 223
                            #28
                            Re: Asset UPnP R7
                            I indexed the custom tag ALBUM TYPE in beta 3 and made the tree ALBUM TYPE > root, but it doesn't work. In Asset Control, I can select an ALBUM TYPE and return to the root, but when I go on selecting ALBUM the listing is empty.
                            This gave me some headache until I tried the same with some variant spelling:
                            ALBUM TYPE - does not work
                            ALBUM TUPE - does not work
                            ELBUM TYPE - working
                            ELBUM TUPE - working
                            So it would seem that anything starting with ALBUM doesn't work, except ALBUM and ALBUM ARTIST of course.
                            (I didn't use ALBUM TYPE in beta 2, so this is tried in beta 3 only)
                            • RLANE
                              • May 2011
                              • 138
                              #29
                              Re: Asset UPnP R7
                              Updated to beta 3:
                              I installed B3 and confirm - Album Artist issue resolved.
                                • 46231
                                #30
                                Re: Asset UPnP R7
                                Very odd, I created some tags 'ALBUM TYPE' in flac files, added this to the databasefields:
                                ALBUM TYPE
                                And to AssetUPnPDefinedBrowseTreev7
                                ALBUM TYPE{_no_track_list_}
                                ALBUM TYPE\root
                                and it works as expected. You have exactly the same?
