DSP Effects R11
This topic is closed.
    • 46160
    DSP Effects R11
    <now released>
    • 46160
    Re: DSP Effects R11
    Updated 18th February
    EBU R128 on by default
    EBU R128 LUFS reference level defaults to -18
      • 46160
      Re: DSP Effects R11
      Update 4th March
      Fixed Crash for ReplayGain if conversion was cancelled (in CD Ripper).
        • 46160
        Re: DSP Effects R11
        Update 6th March
        ReplayGain fix where it would write large RG values for silence.
          • 46160
          Re: DSP Effects R11
          Update 1st May
          New Effect Dynamic Range Compression
          • projeKct
            • May 2014
            • 17
            Re: DSP Effects R11
            This is cool, I love the ReplayGain feature... "EBU R128 LUFS level -18" is my target. But I don't understand the "Warning: Normalisation gain would have resulted in clipping, gain has been reduced to prevent this..." message. I don't want this. Can you make this "feature/correction" optional, please? Most mp3 players have a pre-amp option and also a prevent clipping option, so dBpoweramp shouldn't care about this! In fact, Foobar2000 doesn't care about this, and I'm happy with that! But I would be even happier if dBpoweramp acted similar.
              • 46160
              Re: DSP Effects R11
              Update 20th May
              ReplayGain Configuration page redesigned
              ReplayGain EBU R128 used by default
              ReplayGain EBU R128 defaults to -18 LUFS
              ReplayGain New option - iTunes Album Gain
              ReplayGain New option - disable clip prevention
              ReplayGain New option - identify albums as all tracks in same folder
              Bug fix: When applying album again to a very large collection (perhaps quarter of a million tracks), certain albums would be missed
              Fixed Resample from 192KHz to 88KHz
              • tommybs
                • Jun 2014
                Re: DSP Effects R11
                Apparently clip prevention is now disabled by default in ReplayGain.
                The checkbox "Disable Clip-Prevention" actually enables the clip prevention.
                There are some minor changes in the logfile, I guess that is intentional:
                R10: -dspeffect1="ReplayGain=-albummode={qt}0{qt} -r128 -r128lufs={qt}-23{qt}"
                R11: -dspeffect1="ReplayGain= -albummode={qt}0{qt} -r128lufs={qt}-23{qt}"
                • kareha
                  • Mar 2012
                  • 8
                  Re: DSP Effects R11
                  Would it be possible to make Replaygain take into account Discnumber so multidisc titles are gained separately?
                    • 46160
                    Re: DSP Effects R11
                    Now released.
                      • 46160
                      Re: DSP Effects R11
                      @kareha - it is a tricky one, because there are certain multi disc sets where it is the same album split over different discs, and there are other box sets which are created from dissimilar albums.
                      • lmschris
                        • Jul 2014
                        Re: DSP Effects R11
                        New to the forum. My name's Chris, just registered today, but purchased dBpoweramp in March and have been learning and following the topics since then.
                        I'm a little confused about the Disable Clip-Prevention checkbox. tommybs mentioned that it's already disabled by default, but I don't see it already checked. He also mentions that the checkbox "enables" clip prevention.
                        So my question is, should I check or un-check "Disable Clip-Prevention" to not have dBpoweramp correct the gain?
                          • 46160
                          Re: DSP Effects R11
                          It was a bug whilst in beta which was fixed in full release.
                          The replaygain dsp does not apply the gain, it writes ID Tags. If clip prevention is handled by the player, it can be unchecked.
                          • lmschris
                            • Jul 2014
                            Re: DSP Effects R11
                            Thanks for the reply Spoon. Wasn't sure I'd hear from anyone today, being a holiday.
                            If clip prevention is to be handled by the player, then wouldn't I want to "Check" the box? From what I see, checking the box prevents (disables) dBpoweramp from doing the clip prevention, making the player then responsible for handling it.
                              • 46160
                              Re: DSP Effects R11
                              That is correct.
