[codec] m4a FDK AAC Encoder
This topic is closed.
    • 44008
    We will be phasing out the Nero encoder and replacing with this newer FDK version.
    Includes also a m4b encoder.
    <now released>
    Encoder.exe"]dBpoweramp-Codec-m4a FDK (AAC) Encoder[/URL]
    This install contains both 64 bit install (for dBpoweramp R15 beta 64 bit) and 32 bit install. By default the install will match your dBpoweramp (32 bit or 64 bit).
  • zoan06
    • Feb 2013
    Re: m4a FDK AAC Encoder
    Installed but unable to get it to work. Tried to convert a FLAC file and it does nothing.
    I still have the Nero encoder installed. Do I need to remove it?
      • 44008
      It is independent of the Nero encoder.
      When you say does nothing, you mean it converts and finishes, but there are no output files? no errors?
      • zoan06
        • Feb 2013
        No, it doesn't convert anything. The time elapsed keeps going up but the files will not convert at all. I eventually have to use task manager to get it stop, as clicking cancel doesn't work.
        I will uninstall and reinstall to see if I possibly did the install wrong.
        EDIT: Found the problem! My antivirus was blocking it as a "questionable" program. I took off the blocker and it works fine now.
        • vozer
          • Jun 2013
          Hi admin.
          This fdk-acc encoder doesn't have any custom option such as he-aac mode, cut-off frequency or vbr mode. When i check the spectrum of output file created by this encoder i see although encoding at 192kbps but the frequency is cut off at 16 khz.
          I hope you will add an option for cut-off frequency and vbr mode. Thanks.
            • 44008
            HE and HE v2 engage automatically under set bitrates (96 and 48 respectively)
            The VBR mode for this codec is only for very low bitrates (less than 64 kbps from memory, adding a VBR option would confuse in our opinion).
            • Christian_S
              • Oct 2008
              • 21
              Are you sure about the low bitrates. This response in hydrogenaudio suggests something different. I can't judge either statement.
              • deluge
                • Jul 2013
                It seems that FDK AAC Encoder never goes above 17kHz even if the bitrate is set to 512kbps.
                Is there any way to fix this serious issue?
                • pmredulla
                  • Aug 2013
                  Why do you need to phase out the Nero AAC encoder? It is somewhat more "flexible" compared to the fhgaac encoder, in my opinion.
                    • 44008
                    We will still offer it, but I have the feeling that Nero will discontinue it over time and we are not allowed to host their component.
                    • JonnyOne
                      • Sep 2013
                      Very interesting release! A lot of thanks for this :smile2:
                      I LOVE dbpoweramp stuff, and in the past my Alpine car radio cant play aac from nero, now with FDK all is ok. 200 kbps with this is better than lame slow vbr v -0 extreme (around 260 kbps)
                      • MikeCerm
                        • Feb 2005
                        • 37
                        Bitrates below 64kbps fail with this error: Error converting to m4a FDK (AAC), 'C:\Users\Mike\Documents\Podcast_355.mp3' to 'C:\Users\Mike\Documents\Podcast_355.m4a'
                        Could not write to the worker process: file access error [clEncoderExternal::EncodeBlock]
                        Given the limitations of this encoder -- no VBR, no mono, no control over HE/HEv2 -- it seems completely useless to me. Also, I've searched the web for analysis of the audio quality, but found basically no mention of it anywhere. The 17-KHz limit ruins it for high bitrates, and the failed-conversion errors means I can't even test low bitrates (for podcasts and stuff).
                          • 44008
                          What were the source attributes of the mp3?
                          • JonnyOne
                            • Sep 2013
                            Hello. I have maked a new fdkaac.exe using this:
                            fdkaac_autobuild
                            I have replaced the new exe in folder "C:\Program Files\Illustrate\dBpoweramp\encoder\m4a FDK (AAC)". In the encoded m4a files, i see in tag "fdkaac 0.3.0, libfdk-aac 3.3.3". Anyone knows what are the changes in this new version?
                            P.s.: sorry for my bad english... :p
                              • 44008
                              >New option --moov-before-mdat was added at 0.3.0
                              This addition would not be used by dBpoweramp as we actually internally already move the moov before mdat...
