Newest Beta: Sveta Portable Audio
This topic is closed.
    • 46220
    Sveta Release 4 Beta 4.3:
    Main changes: Shows Initializing Sveta on start, WMA v9 now shows all options - will work through Convert To >>, Fix for sending files on 'Convert To', Fix for Creative Detection.
    Beta 4.3 fixes creative rip from CD to device problems.
    dMC Release 1.1 fixes a bug where tags would not be transferred to a portable player on Convert To >> Player
    Download:
    2.4MB (includes dMC Release 10 RC1.1)
    *** After install run 'Sveta Add Devices' - remove your device and add it once more to add any new extra features / fixes ***
    Changes
    Sveta Explorer - double clicking file in local file list uploads it to portable
    Sveta Explorer - file list type of mp4
    Sveta Explorer - no longer can rename ..
    Sveta Explorer - no longer can delete ..
    Sveta Explorer - no longer counts .. or folders as tracks (total at bottom)
    Sveta Explorer - New 'Audio' button, so can convert or smart convert
    Sveta Explorer - Shows detailed popup info on a local file if hold mouse over the icon for 2 seconds
    Sveta Compression DLL - added a smart conversion mode - click 'smart' and enter formats (or bitrates) that should not be converted, just sent as is.
    Bug Fix: Certain devices would only save the last track transfered in a 'Convert To >> Portable'
    Bug Fix: Stops other Svetas accessing the same device
    Bug Fix: Sveta Add Device was searching for new devices on a 2nd thread, this caused problems for COM object devices (Creative range!)[COLOR=Red]
    Last edited by Spoons; November 20, 2003, 01:30 PM. Reason: i tried to make the thread title color red. but didn't work.
    • 46220
    Updated to Beta 2
      • 46220
      Updated to beta 3
        • 46220
        Re: Newest Beta: Sveta Portable Audio
        Updated to Beta 4 with a Creative Player detection fix.
          • 46220
          Updated to Beta 4.1, with dMC Release 1.1 fixes a bug where tags would not be transferred to a portable player on Convert To >> Player
            • 46220
            Updated to 4.2 - again a Creative Player detection fix.
              • 46220
              Updated to 4.3 - Creative Rip from CD fix.
                • 46220
                Now Released from Beta.
