Sveta Portable Audio mpio FL FD FY Driver
  • FD100-user
    Sweet! You're doing a great job man!
    • Joseph
      • Oct 2002
      • 211
      I've been using it for a week now, no new problems.
      - Joseph
      • Cosmo q
        • Oct 2002
        • 9
        I had the following problem. I deleted a folder using SPA. The files and folder was gone, but it didn't free up the space. I had to reformat the internal memory to get it fixed. I don't have a memory card so I can't try that. Deleting a file doesn't give any trouble.
        Cq
        • Joseph
          • Oct 2002
          • 211
          When combined memory option is on in Sveta, Using my FL-100 while I have an SD Card inserted, any time somthing changes on the internal memory, the External memory also refreshes which can be time consuming.
          - Joseph
            • 46220
            Cosmo, is it only folders that do this? if you delete files is it ok? also if you delete a folder, quit, then come back into Sveta does it show the correct free space?
            • Cosmo q
              • Oct 2002
              • 9
              #21
              Only folders, deleting a file is no problem. I think the problem is deleting the folder, it goes way too fast compared to the MPIO manager.
              MPIO manager takes the same time to delete a full folder as when deleting all the filles in it. Sveta only takes the time to delete an empty folder.
              Also, the space doesn't come back by reconnecting or using MPIO manager. Currently the only sollution I know of is formatting the internal memory.
              Cq
                • 46220
                #22
                Thanks will look into it.
                  #23
                  FL-100 Drivers
                  Would it be possible to have your drivers resolve the FL100 as a USB drive or such an utility ? I like your program a lot, but I cannot install it at the office. A small plugin to explorer would be a kick ass feature.
                  -Swifty
                    • 46220
                    #24
                    No it cannot work like that.
                      • 46220
                      #25
                      Re: Sveta Portable Audio mpio FL FD FY Driver
                      Now released (folder delete bug was fixed).
                      Visit Sveta Portable Audio download page.
                      • Cosmo q
                        • Oct 2002
                        • 9
                        #26
                        Thanks, I'll give it a try.
                        Cq
                        • Stoerenfried
                          #27
                          Is it possible that Firmware 1.32 (09-29-2003) is not yet supported? Even though I can add the player, the program itself says "not connected" .
                            • 46220
                            #28
                            Which mpio player?
                              #29
                              Hy,
                              got a problem on my PC. Sveta recognizes my FL100 when adding devices, but it is not "active" when I want do load files to it.
                              I hope it will be possible do send files in both directions and that Sveta does not care about this bloody "DRM" stuff. I am musican and want do copy my music to my friends, since I OWN the Digital Rights in this case.
                              JoeJo
                                • 46220
                                #30
                                If you run Sveta Explorer (the mpio icon on the desktop), it just says 'Connecting to Device'? and never lists the tracks?
