Asset UPnP v4
This topic is closed.
    • 45408
    Asset UPnP v4
    <now released>
  • dvdr
    • Sep 2008
    • 235
    Re: Asset UPnP v3.1
    sound great, will try tonight.
    Question for WHS: is there no WHS installer anymore? Or will you provide one shortly?
    When installing the provided .exe on a WHS with an existing R3: install as "local account" or "as service"?
      • 45408
      Re: Asset UPnP v3.1
      The WHS install will be provided on release, for now if you install as set out, set to Service then reboot the WHS box, that is all that needs to be done.
      • mickc
        • Sep 2010
        • 152
        Hi Spoon - I've loaded the new beta and it's nice to see that bug I reported (jukebox playlist was almost-but-not-quite alphabetical) sorted.
        However, I now have an issue with 3.1 regarding the way it deals with time within a track.
        Firstly, if I press the double arrow keys (to skip ten seconds through a track) my DS appears to reboot. Also, using either Chorus DS or PluPlayer as control points remaining track time is odd.
        In the case of ChorusDS the remaining time is simply shown as '??:??':-
        ...and with Plugplayer the lapsed and remaing times step up in unison, rather than lapsed going up and remaining going down:-
        Any thoughts? With a bit of faffing I could try Kinsky as well if that'll help.
        Regards
        Mick
          Re: Asset UPnP v3.1
          While installing Asset UPnP v3.1, this error was logged in the system log:
          Is this a potential issue?
          TIA
          • audiokaas
            • Jan 2010
            • 56
            Re: Asset UPnP v3.1
            I can confirm the time display problem with chorus and Songbook.
            ??:?? and elapsed and remaining time are the same.
            As a extra question.
            Is it possible to retain all the settings while trying out beta's?
            Is there a setting file I can copy and restore?
            Great to finally see the most played etc fields filled
            Good luck with the bug fixes:smile2:
              • 45408
              Re: Asset UPnP v3.1
              Not a problem.
              I will investigate the time issue. Settings should always be preserved, even through uninstalls.
              • ocoro02
                • Jun 2009
                • 37
                Re: Asset UPnP v3.1
                I seem to be losing album art. I typically browse on an artist/album or albumartist/album basis, and for each of these the album list initially won't display the album art (just the dashed lines where the image would be). If I select and play an album however, the art will display for that album. Often when selecting one album the art may show up for all the other albums too.
                I've tried clearing the cache in the AlbumArtv3 folder in AppData and did a full refresh - no joy, it's still doing it.
                Just gone back to 3.0 - hmm, same problem.
                  • 45408
                  Re: Asset UPnP v3.1
                  It is a problem with your control point me thinks
                  • ocoro02
                    • Jun 2009
                    • 37
                    Re: Asset UPnP v3.1
                    You are correct sir! Uninstalled Kinskydesktop, went back to last stable release (I am a sucker for beta versions), all working.
                      • 45408
                      Re: Asset UPnP v3.1
                      Update 14th July
                      Small update to fix the issue seen on Linn players where the length of the track was not shown.
                      • mickc
                        • Sep 2010
                        • 152
                        Re: Asset UPnP v3.1
                        Update 14th July
                        Excellent - thanks Spoon.
                        Mick
                          • 45408
                          Re: Asset UPnP v3.1
                          New update 20th July
                          Major Addition: Dynamic Browsing - added automatically to the default tree (if you have an existing Asset, open Asset Configuration >> Advanced Settings >> click Restore Default).
                          Allows an infinite browsing based on inclusion and exclusion, for example you are having a party and you want Music from the 80's and 90's, but you want to exclude the Genre Classical and Genre Soundtrack, you would:
                          Browse into Dynamic Browsing, lets do the included items first, so select Year >> 1980's, and Year again >> 1990's. Now the exclusions, select [Exclude] >> Genre >> Classical, and [Exclude] >> Genre >> Soundtrack, finally[List Albums] is selected (or [JukeBox Album Selection] for a random selection of albums).
                          New Addition: For the Year items a decades item is created, for example 1980's, 1990's
                          • brantome
                            • Apr 2009
                            • 22
                            Re: Asset UPnP v3.1
                            Excellent update - could be very handy.
                            Would there be a way of implementing a selection from what's currently playing e.g. if you're listening to a track that may be in a playlist, it'd be useful to be able to, say, jump to a selection for that album, artist, genre or whatever.
                            I find I tend to listen to playlists or a random selection then upon hearing a track think it'd be good to listen to its album again all the way thru, or another track from that artist. It can sometimes be a bind to have to navigate all the way from base camp to find it...
                            Cheers
                              • 45408
                              Re: Asset UPnP v3.1
                              That is more of something a control point should offer, in that the interface for doing so would naturally fall to the control point.
