Asset UPnP v4
This topic is closed.
    Re: Asset UPnP v4 - installation error via RDC on WHSv1
    Right click on the .msi and select uninstall, then install by double clicking it.
    • drgrittani
      • Jun 2004
      • 10
      #92
      Re: Asset UPnP v4
      Tried that, it gives me the same message when I select uninstall.
        Re: Asset UPnP v4
        Uninstall from start >> control panel >> add / remove programs
        • drgrittani
          • Jun 2004
          • 10
          #94
          Re: Asset UPnP v4
          I was going to do that, but I have a registered copy, will it remain registered if I uninstall and install the beta?
            Re: Asset UPnP v4
            Yes
            • audiokaas
              • Jan 2010
              • 56
              #96
              Re: Asset UPnP v4
              I love the coverart for the genre, artist group etc.
              On some though I get no coverart, one genre gets no coverart as well as one composer.
              Could you tell me how Asset finds the art and which image it uses to send to the control point.
              It would be great to have a picture of say the Beatles for the artist and the album covers for the album listing?
              Thank you.
              Great program:smile2:
                Re: Asset UPnP v4
                If there are multiple genres in a file, and the genre is 2nd then album art would not appear upstream for that item, if the genre only appears as a 2nd item of a multiple file.
                • audiokaas
                  • Jan 2010
                  • 56
                  #98
                  Re: Asset UPnP v4
                  I'm not sure I understand, is it a bug then when no albumart appears upstream?
                    Re: Asset UPnP v4
                    No, a limitation if having multiple genres in single files.
                    • Oliviander
                      • Sep 2010
                      • 36
                      #100
                      Re: Asset UPnP v4
                      Strange Sort Behavior
                      Hi Spoon
                      I have activated the following options
                      The Artist and Album Handling: Leave as is
                      Artist Sort Handling : Ignore Sort Values
                      All Tags are kind of: Beatles, the (Artist, Album Artist etc.)
                      But the Artist Listing shows Beatles under
                      T The Beatles
                      I wouldn't expect that (And as I remember it wasn't the case under R3)
                        Re: Asset UPnP v4
                        Asset will always internally normalize Beetles, the to The Beetles
                        • DaFork
                          • Jan 2011
                          • 67
                          #102
                          Re: Asset UPnP v4
                          Bump. When can we expect a new release or possibly the non beta Asset4?
                            Re: Asset UPnP v4
                            Full release before Christmas hopefully.
                            • DaFork
                              • Jan 2011
                              • 67
                              #104
                              Re: Asset UPnP v4
                              Will that ship with Search *crosses fingers*?
                              • dvdr
                                • Sep 2008
                                • 235
                                #105
                                Re: Asset UPnP v4
                                Hi
                                I am using the latest beta of Asset on a WHS 2011 platform (two cores, HP N36L). Since I do have a huge music collection, it takes a while to scan, when adding new music.
                                What really makes the whole scanning process slow, seems to be "Combine Artists". Watching the scanning process, "Combine Artists" is displayed for more than 2 - 3 hours, while the rest of the scanning process seems to go pretty quick.
                                So I thought of just unchecking the option "Combine Artists". I basically do know, what "Combine Artists" does, especially correcting mis-spelled artist's names. But: what would I really loose, when not using this option, what is the downside, how "bad" would the database become?
                                Thanks for your help!
                                [SIZE="1"][B][I]WHS ACER H340 w/ Asset V3, Linn Sneaky, Plugplayer/Songbook/Kinsky, Music mostly *.flac[/I][/B][/SIZE]
