what would cause slow index detection
  • Teknojnky
    • Dec 2006
    • 323
    like 3-7 minutes to scan disks, the same disk put in a different drive scans in a few seconds.
    the affected drive is a sata bluray-rom drive listed as:
    ATAPI -iHOS104
    on the dbripper drive selector
    drive appears to rip fine once the gap/indexes are detected.
    the gap detection goes fast, only a few seconds
    the index detection takes 3 to 7 minutes.
    I don't believe it happened before on r14 final, and this is first rips I've done since installing 14.1 beta
    Want to see [url=http://www.last.fm]Last.FM[/url] relationships using your own library?
    Want a random mode based on track and artist relationships?
    [url=http://www.mediamonkey.com/forum/viewtopic.php?t=24879]Try Last.FM Node[/url] for [url=http://www.mediamonkey.com]MediaMonkey 3![/url] ([url=http://img178.imageshack.us/my.php?image=lastfmnodemediamonkey3fj3.jpg]screenshot[/url])
    [url=http://www.last.fm/user/teknojnky/?chartstyle=Geldropdown-small][img]http://imagegen.last.fm/Geldropdown-small/recenttracks/teknojnky.gif[/img][/url]
    Re: what would cause slow index detection
    Try going back to R14
    • TechVsLife
      • May 2007
      • 95
      I'm seeing the same behavior in R14 final (latest) with an internal blue-ray reading drive. The drive is listed as:
      HL-DT-ST BDDVDRW CT21N
      specs are here:
      I did NOT install the 14.1 beta.
        I will keep an eye out for other people who might be having the same issue.
        • TechVsLife
          • May 2007
          • 95
          Thank you. The other thing I notice is that no "drive read cache" was detected (and cachex doesn't get any info from the drive). running win 7 x64 sp1.
          • m4rk
            • Feb 2010
            • 16
            FYI
            When gap is elected to be shown in the columns I am getting very, very slow gap detection and indexing with one of my drives and DBPA R14 winxp. I haven't dipslayed the gap column before so I can't say if it occurred with R13 as well.
            SAMSUNG - CD-R/RW SW-248B very slow gap detection and even slower/stuck in indexing 5mins per track!!
            HL-DT-ST-DVDRAM GSA-4163B takes a few seconds fro both gap and indexing
            What difference does this make to the rip anyway? Is it just for information or does it affect my FLAC files? Do I ahve to re-rip with this selected? :o
