mp4 Encode and Decode Codec
    #31
    Mp4 - Switched to fastenc and new mp4creator.
    Fastenc is very experimental, and though it is faster than aacenc, it also leads to much higher bitrates for the same quality. Would it be possible to switch back to aacenc, as most people, me included, would probably rather have their encoding time slightly increased, than quality being decreased for speed purposes.
    Anyway I saw on the HA forums that you were working on a quicktime codec, if so then it is even better than switching back to aacenc, so ignore my comment, and keep up the good work!!
    thanks
    pierugg
      • 46220
      #32
      If you rename aacenc to fastenc and overwrite the fastenc it will work fine.
        #33
        Ok thanks
        Any precisions available on the quicktime codec?
        Pierugg
          • 46220
          #34
          Define 'precisions' please, I dont understand the question.
            #35
            maybe iam in the wrong place and going about it all wrong but iam trying to convert mpeg's to mp4 so i can upload them onto my 3 phone. it says that they must be mp4 format and it converts and uploads them fine but when i play them on the phone i get only sound and no video ! any help at all would be greatly welcomed ! !
              • 46220
              #36
              My stuff is only audio, no video support.
                • 46220
                #37
                This beta closed and replaced by Beta 4
