Asset Control
This topic is closed.
This is a sticky topic.
    • 46376
    Asset Control
    Asset Control (a UPnP / DLNA control point) is billed as the control point you have been waiting for .
    In UPnP there are: Server / Control Point / Renderer, where the Server catalogues tracks, Control Point creates playlists from the Server and controls the Renderer (player), all 3 elements of UPnP could reside on the same computer, or could be on separate devices.
    Asset Control is a control point built around the central idea of touch control (although functions in the normal non-touch sense), and shines on tablet based PCs.
    Development Stage
    Currently designated as a Beta, we are at around 99% completed as far as features are concerned (for the initial release).
    A word on functionality: to close Asset Control click or move the mouse to the top right for the close box to appear.
    Download (for Windows 10 / 7 / Vista / XP)
    907 KB
    Please direct all discussions regarding Asset Control to:
    Configuration Options
    Asset UPnP Configuration exposes a number of options, after changing any options restart Asset UPnP. Some of the less obvious options:
    Color Scheme - changes between Black or White display
    Display - alters how Asset Control Appears, Full Screen Places Asset Over the TaskBar, whilst Maximized shows the Task Bar. It is also possible to not have the close box in the top right, thus making Asset the only application which is effectively running.
    Main Browse View
    Label Size - sets the size of the text in the main display.
    Album Display Alters how Album browsing appears.
    Playlist
    Auto Scroll Current Playing - if enabled will keep the current playing item on screen
    Now Playing
    Play Now Display / Secondary Display - these are the values displayed when playing, the secondary display is invoked when the genre matches any of the entered values.
    • 46376
    Re: Asset Control
    'To do' Work-Schedule
    The road-map we have to implement into asset control:
    [ ] Activate Linn DS Extensions
    [ ] Search Functionality
    [ ] Playing Now Views (there will be many additional views)
    [ ] Filter integration within current view (imagine looking at Artists and select Filter on Genre 'Pop', or Year 1980's..., or sort the albums on release year, or filter the artist view to show just Album Artists / Contributing Artists,
    [ ] Multiple Audio Collection Handling (based on people, ie you have a collection of audio tracks, your spouse has some of yours and their own)
    [ ] Jukebox mode - set playback criteria and let it play with a random selection
    [ ] Metadata editing - rate tracks, fetch album art, etc all from the control point
    [ ] Multiple Platforms - Apple iPad, iPhone, iPod Touch, Mac
    Features Worth Mentioning
    The browsing the of UPnP tree should be the fastest out-there with near instant results even though there can be 1000's of artists loading in the background.
    On the Playing Now if no input happens in 20 seconds the controls on the screen fade out to leave just the playing details.
    Smart Playlist Shuffle, in that you can shuffle your playlist, then cancel the shuffle at any-time and the original order is remembered. Also shuffle can be done on a track, album, or album (and tracks in album) basis.
    I am also sort of embarrassed by the presentation of my audio tracks as shown in the screen shots, it is a case of 'the cobblers shoes', I am in the process of reripping all my tracks so they have high res-art work and AccurateRip verification (my rips are from 4-5 years ago in many cases).
      • 46376
      Re: Asset Control
      Update 13th May 2010
      Minor update, which allows Asset control to work where previously it would have a red circle through the track, on certain devices (ie the track could not be added to the playlist).
        • 46376
        Re: Asset Control
        Update 14th May 2010
        Enables Asset Control to be started with a -debug command-line option, ie Start >> Run:
        "C:\Program Files\Illustrate\dBpoweramp\Asset Control.exe" -debug
        This will display a debug log after Asset Control has exited, which is useful for those situations where tracks have a red circle through them and cannot be added to a playlist.
          • 46376
          Re: Asset Control
          Minor Update
          LPCM support for renderers devices which supply a frequency and channel count in supported format (ie if you saw a red circle with a line through, it should be fixed)
            • 46376
            Re: Asset Control
            Update 26th August
            Work as resumed on Asset Control again, it is the primary focus once more (R14 and Asset UPnP are code complete for their respective releases).
            This first update improves the playback (previous versions could stall when working through a playlist).
            It is hoped there will be regular updates, I know there is a long list of people wishing for us to activate the Linn extensions, however we have to be sure that standard UPnP is functioning as should, before moving on with something which bypasses this part.
              • 46376
              Re: Asset Control
              Update 11th September
              A significant update as far as usability is concerned.
              Changes:
              Volume can only be changed by clicking on position slider, not anywhere on volume scale (to stop accidental volume max)
              Volume added + - buttons
              Added new fast jump to top or bottom of list buttons
              Have composer, conductor showing for classical (genre=classical) music
              Auto selects last used Server and Renderer
              Mouse mouse to top right corner and gets minimize and close buttons
              Bug Fix: certain media files (such as mp3) would have red circle even though they were supported by player
              Bug Fix: Playing screen was not cleared when playback had stopped
              Bug Fix: if have t1 and t2 and t3 (in pl all different art), set t2 playing and remove t1 from PL, in the now playing it showed t3 art
              Bug Fix: Play Position (text) could cut short display
                • 46376
                Re: Asset Control
                Update 14th September
                Options exposed for Asset Control (see new Asset Control Configuration icon in start menu)
                bug fix: playlist scroll down arrow was scrolling up...
                bug fix: Playing Next on the Now Playing screen shows when the play buttons are on screen
                  • 46376
                  Re: Asset Control
                  Update 25th September
                  The one a certain segment have been waiting patiently for - DS Extensions! now implemented. We needed to hold off on implementing this to be sure that the non-DS playlist handled playback was working as should.
                  Changes:
                  bug fix - other devices on the network could interfer with current playing device (at the control point)
                  Linn Playlist extensions are now active
                    • 46376
                    Re: Asset Control
                    Update 23rd September
                    Work is progressing on Asset Control once more (3 cheers!), it is now on a run down to full release. The display has been improved, is Davaar compatible. We still contend this is the fastest control point you will find. Our plans shift over time, but we still hope to have Asset Control on iOS, Android and Windows 8 Metro UI. Asset Control will be a 100% free product.
                    Changes:
                    Rearranged Display
                    Updated to Open Home Specification (davaar)
                    Power Button for Linn devices
                    Uses UPNP Server album art size feature
                    Album art performance enhancement
                    Sorts track listing with disc number (if supported by server, such as Asset UPnP)
                    bug fix - fixed UI freeze dead lock
                    bug fix - starting Asset Control with a Playlist read from DS would result in wrong foreign characters
                    bug fix - could show art in poor resolution
                    bug fix - playing screen shows the artist from other upnp servers
                    bug fix - adding a whole artist '>' to playlist no longer adds duplicates
                    bug fix - The minimize and close icons in the top right no longer appear also when AssetControl is already minimized
                      • 46376
                      Re: Asset Control
                      Update 14th March
                      Bug Fix: further lockup solved
                        • 46376
                        Re: Asset Control
                        Update 16th March
                        These updates are like buses
                        * Fixed freeze when adding items to playlist
                        * Fixed occassional wrong playlist item order
                        * Dropped hook DLL, now using a shell hook window
                        * Mouse wheel works with the playlist
                        * also made mouse4 navigate back.
                          • 46376
                          Re: Asset Control
                          Update 29th March
                          Further speed (visual) and display bug fixes
                          Asset Control is getting closer to release now.
                            • 46376
                            Re: Asset Control
                            Updated 25th October
                            A fresher new look
                            Updated to read artists from upnp better
                            Bug fix: would render lines incorrectly
                            Other minor bug fixes
