Accurate Rip Test #3
  • chami
    • Oct 2002
    • 13
    Old Mp3 (Lame).dll ?
    On the current dMC including Accurate Rip (dMC-r10-ARtest3.exe), the alt standard Bug (limit to 224) seem's to be back.
    I can't find the DLL patch on the forum.
    Did I miss something ?
    Thank you,
    Olivier.
      • 46220
      Go for:
      Which will have it.
      • cdjockey
        Accurate Rip and EAC
        Spoon,
        I've been watching the progress of accurate rip for a while now and i think it is a great idea.
        I personally use EAC in the main and have become 'used' to it, i was wondering if you had talked to the EAC author with a view to adding support?
        If you have, do you have any indication of if or when it could happen?
        Keep up the good work :-)
        cheers
        cdjockey
          • 46220
          There are only two things that need to be done to nail the AccurateRip down, that is - support for multioffset discs and the auto uploading of results through ftp, once those two are completed then it can be served up
          • stenvex
            Accuraterip.com DL page still has the test3 file. Should I get this beta5 instead?
              • 46220
              #21
              Beta 5 is a later release than test 3.
              • stenvex
                #22
                Trying to help out with the disc DB. Have about 100 discs, only 2 of which are on the key disc list (a double CD album). Install was fine, drive was recognized, offset detection was fine, test rip progress without errors, except...
                Track Ripping Status [Disc ID: 002016e9-9511200b]
                1 Accurately Ripped (confidence 1) [d0c18bb3]
                2 Accurately Ripped (confidence 1) [e73d2a3f]
                3 Accurately Ripped (confidence 1) [28fe584b]
                4 Accurately Ripped (confidence 1) [ba145968]
                5 Accurately Ripped (confidence 1) [366cf52b]
                6 Accurately Ripped (confidence 1) [26dbb67c]
                7 Accurately Ripped (confidence 1) [185480b1]
                8 Track not present in database. [d037e446]
                9 Track not present in database. [a3feeb6e]
                10 Track not present in database. [8c35952d]
                11 Track not present in database. [2479c192]
                _______________________
                Track(s) Accurately Ripped: 7
                **** Track(s) Not Ripped Accurately: 0 ****
                Track(s) Not in Database: 4
                This was: Nick Warren - GU018 Amsterdam (CD1)
                Advice?
                • vinnie97
                  #23
                  Chances are you have a European release. I believe the US release is in the database.
                    • 46220
                    #24
                    Perhaps, or maybe the person who added that album to AccurateRip on ripped those first tracks.
                    • Cosmo q
                      • Oct 2002
                      • 9
                      #25
                      Problem configuring
                      I'm trying to use the Accurate Rip system. I installed the beta dmc and the database. I have 3 CD's that are in the key list. (Daft Punk - Discovery, The Bloodhoundgang - Hooray for Bobues and Zwan - Mary Stars of the Sea). When I insert those I get the accurate rip system dialog, I configure, it asks for another CD (my cd-rom isn't in the list) and I insert the second, then it still needs another CD, even after the third key-disk, it still asks for one more. Is there anything I can do about this.
                      I have a Sony DRU-510A so it's pretty new, I have the same with an older pioneer DVD-Rom drive.
                      Greetings,
                      Cq
                        • 46220
                        #26
                        Not much, just keep feeding it CDs (the results it is getting from your CDs have different offsets on the CDs, until two sets match it will ask for another disc).
                        • Razgo
                          • 2532
                          #27
                          I just noticed an oddity.
                          [color=red]when i rip to mpc accurip tells me[/color]-----
                          Track Ripping Status [Disc ID: 0011b918-7b0ba709]
                          1 ** Rip not accurate ** (confidence 1) [cea45097] [a1ca68eb]
                          Track(s) Accurately Ripped: 0
                          **** Track(s) Not Ripped Accurately: 1 ****
                          Track(s) Not in Database: 0
                          [color=red]but when i rip to ogg it reports[/color]:====
                          1 ** Rip not accurate ** (confidence 2) [56ed21b5] [cea45097]
                          the other odd thing i ran this test on the same file 3 times.
                          twice when ripping to ogg it told me it wasn't in the database at all except for the third time.
                            • 46220
                            #28
                            Each time you rip the results go into your local accurate rip database, so for example:
                            say you had submitted a disc
                            two other people submit an offsetted disc - theirs will currently appear in the database
                            you rip once - it will say inaccurate
                            you rip again - your 2 matches their two
                            you rip again - your 3 beats their 2 so it will say accurate.
                            • Razgo
                              • 2532
                              #29
                              ah ok, it's kind of like a report card system :D
                              but it should have not reported it wasn't in the database after it said it was the first time? that was my oddity. as it's either there or it isn't.
                              • Razgo
                                • 2532
                                #30
                                I sent the database in to dbpoweramp@dbpoweramp.com
                                the one i was questioning is a track called "Allegro from the Violin Concerto #3 in G Major"
                                the album is also listed in accurip page( my submission) called
                                Don Campell - Music for the Mozart Effect, Volume I
