Asset uPNP & DLNA
This topic is closed.
    • 46220
    Re: Asset uPNP
    It is possible
    • bsd107
      • Nov 2008
      • 17
      Re: Asset uPNP
      I wanted to try this on my WHS.
      Does dBpoweramp have to be installed on the same machine? Or can Asset uPNP be installed stand-alone?
        • 46220
        Re: Asset uPNP
        Stand alone, I will create a WHS install next week which preconfigures as a service and shares the right folders.
        • ShiTou
          Re: Asset uPNP
          Hello,
          I would second dvdr's approach in organising music in a more "musical" manner.
          My feeling is that most of the music related software was written by and for pop music people, and even the uPNP spec shows that the authors did not necessarily think of classical music or jazz.
          Ideally I would like to be able to browse similar to:
          Mode/Popular
          Mode/Jazz
          Mode/Opera
          Mode/ :
          Mode/Classical
          Mode/Classical/Epoch
          Mode/Classical/Type
          Mode/Classical/Composer
          Mode/Classical/Performer
          Mode is not necessarily Genre, but the way music is browsed. For popular music the approach artist/album/song is sufficient, for Jazz composers and arrangers are as interesting to know as performers.
          In classical music, Epoch would be:
          Epoch/Baroque
          Epoch/ :
          Epoch/Wiener Klassik/
          Epoch/Wiener Klassik/Mozart
          Epoch/Wiener Klassik/Haydn
          In Type I would like to see:
          Type/String Quartett
          Type/Piano Sonata/
          Type/:
          Obviously, the same subtree could appear for busy composers if they apply, i.e. if a set of works can be combined into a logical group:
          Mode/Classical/Composer/Beethoven
          Mode/Classical/Composer/Beethoven/String Quartett
          Mode/Classical/Composer/Beethoven/Piano Sonata
          Going beyond that, if I have several recordings of one sonata:
          ../Beethoven/Piano Sonata/No32 Opus 111/
          ../Beethoven/Piano Sonata/No32 Opus 111/Alfred Brendel
          ../Beethoven/Piano Sonata/No32 Opus 111/Emil Giles
          So ideally, a uPNP server should allow:
          1. tag music beyond id3 tags though some maintenance interface
          2. allow more sophisticated content browse and search.
          Last but not least, the server should run on Linux as this less resource hungry OS is most likely used in embedded devices.
          Cheers.
          • anders
            • Dec 2003
            • 15
            Re: Asset uPNP
            I'm pretty excited by this -- most of the uPNP servers out there are iffy at best.
            I tried getting Asset to work with both my PS3 and XBox 360, with Asset running on my Windows Server 2008 box.
            I was able to get the library up and running -- it scanned through my music folders (and pretty quickly, too,with 15K tracks), but when I try to connect with my XBox it tells me the server disconnected, and the PS3 tells me there's a DLNA protocol error.
            Is it supposed to work with these playback clients yet? Is it supposed to work with Windows Server 2008? I'm happy to work with you to debug if/when that makes sense.
            anders
              • 46220
              #21
              Re: Asset uPNP
              XBox is no go ATM.
              The PS3 - where does it show that error, whilst browsing the artist trees? or before anything shows?
              • anders
                • Dec 2003
                • 15
                #22
                Re: Asset uPNP
                XBox is no go ATM.
                On the ps3 the error shows up right away after selecting the server, before anything is displayed.
                  • 46220
                  #23
                  Re: Asset uPNP
                  anders can you email me please:
                  • bsd107
                    • Nov 2008
                    • 17
                    #24
                    Re: Asset uPNP
                    Can't wait to try this on my WHS and PS3!
                    • anders
                      • Dec 2003
                      • 15
                      #25
                      Re: Asset uPNP
                      http://www.dbpoweramp.com/email.htm
                      done.
                      anders
                        • 46220
                        #26
                        Re: Asset uPNP
                        Big Update to 0.6 beta - download as first message
                        UPnP - AIFF works now
                        UPnP - Apple Lossless added
                        When Forced Wav streaming enalbed, no longer uses temp files, live streaming
                        Media types written to an editable file %appdata%\dBpoweramp\uMediaLibrary\AssetUPnPDefine dAudioTypes.txt
                        Browsing tree total rewrite, many new browsing features such as Genre >> Above 4 Star Rating, edit the tree by editing: %appdata%\dBpoweramp\uMediaLibrary\AssetUPnPDefine dBrowseTree.txt
                        Server Name now part of UPnP name
                        Upgrading from previous beta
                        Uninstall Asset UPnP, reboot computer, browse to:
                        and delete all files. Then install new beta.
                        Yet to do
                        album artwork
                        multiples - artists, genres, etc
                        xbox compatibility
                        ps3 compatibility
                        albumfolder can return albumartURI
                        playlists
                        • Marek-f
                          Re: Asset uPNP
                          Hi Spoon.
                          I try it with my Netbook at the T+A MP1250R Media Player. It dosen't works. The T+A dont't display this uPNP programm.
                          My T+A works with Windows MediaPlayer 11 (no Flac support) and Twonky (only demo).
                          Marek
                          • dvdr
                            • Sep 2008
                            • 235
                            #28
                            Re: Asset uPNP
                            again, an extremely valuable update, thanks!
                            Especially switching to "streaming instead of temp-converting to wav" is a great update, and the editable music-tree already now matches more of my needs than any other upnp-server has ever been able to give me until now!!!!! Thanks!
                            Would you mind giving a hint about AssetUPnPDefinedAudioTypes.txt ?
                            There's a list of file-types - would we need to edit that file somehow to match requirements of certain clients?
                            I was wondering, whether this was possible, and tried to find that out by myself (with no luck, yet):
                            Right now, I need to set "force to wav" to play for example an m4b-file - would that be editable somehow in that configuration file, so that if asset-upnp encounters a non-compliant file it would set itself to "stream to wav"?
                            I tried to reach that by adding an entry
                            Code:
                            .m4b
                            http-get:*:audio/m4b:DLNA.ORG_OP=01
                            audio/m4b
                            (That would be the official mime-type for m4b)
                            but it would not work without "force to wav" enabled.
                            Thanks again for developing this and your great support!
                            [SIZE="1"][B][I]WHS ACER H340 w/ Asset V3, Linn Sneaky, Plugplayer/Songbook/Kinsky, Music mostly *.flac[/I][/B][/SIZE]
                            • Offwhite
                              Re: Asset uPNP
                              This looks very interesting to me.
                              I have tried to use it with my Denon AVR-3808CI, but after starting the Asset-UPNP server, the Denon shows a new entry for it:
                              Asset UPnP [computername] (Not Authorized)
                              So I cannot connect. Is that normal at this beta stage or am I missing something? Would we at some future point expect this to work?
                              Have always appreciated your tools, am also looking forward to this one!
                                • 46220
                                #30
                                Re: Asset uPNP
                                Another significant update:
                                Updated to 0.7 beta. Compatibility with Songbook and PlugPlayer (iPod Touch/iPhone) UPnP controllers has been completed.
                                Added album art
                                Added extra fields for renderer can display album, artist, etc
                                Tested compatibility with SongBook & Plug Player
                                fix: if no database asset shows tree items
                                Download as first message.
                                It is hoped that a v1.0 release will be completed very early in the New Year. DLNA certification is also being investigated.
