Again Problem writting tags!
  • TURBO
    • Jan 2003
    • 14
    When I am in my music collection program and I fix a tag for a mpc file, ok I can see the fixed tag and then I right click the song /advance /rewrite Id tag, just to make sure is rewriten to the file. Well when I go back to the song /advance /refresh from Id tag, voila, the old tag re appears. So the tag is never writen. Can someone confirm this. Is there a fix for this behavior?. Thanks.
    Check that your files are not read-only.
    • TURBO
      • Jan 2003
      • 14
      Thanks Spoon, but the files and the folders are fine. If that is happening should be a bug, could you try to do the same that I did with the tags?. To see what happens?. Thanks.
      I am using:
      dBpowerAMP-r2beta10.exe
      dBpowerAMP-codec-musepack.exe
      dMC-AccurateRip-db.exe
      dMC-PowerPack-Registered.exe
