Musepack (mpc) R8 (using SV8)
    • 46220
    Re: Musepack (mpc) R8 (using SV8)
    Updated (allows the encoder to be used from the new BenchMark Tester)
    • chileboy
      • 96
      All mentions of SV7 are for this encoder (even though it is an sv8 encoder), you can still edit the replay gain values for sv7 files. The Issue with the existing sv7 decoder + encoder is that it will not display RG values if they are 0.0, they are added though.
      OK, I still don't understand - does the SV8 (beta) encoder write SV7 files?
      Or, let me ask it this way - if I want to write SV7 .mpc files, and have the RG tags properly written, what codecs should I be running?
      - Mark
        • 46220
        You could use this codec and replace the mpcenc.dll in \musepack
        We will add both sv7 and sv8 encoders before release.
        • chileboy
          • 96
          Just wanted to LYK (belatedly) that this works - I was a bit confused at first because there was no .dll in that folder, it's an .exe. But I saved the folder from the SV7 install, installed the beta codec, and replaced the new folder with the old, and all seems well.
          Thanks!
          - Mark
          • hd0
            • Jan 2009
            • 12
            SV8 final is out:
            any chance for an update? :smile2:
              • 46220
              #21
              Updated to SV8 1.30 Stable
              Download as first message.
              • chileboy
                • 96
                #22
                Spoon, SV8 isn't applying the Replay Gain tags at all now, either while ripping or converting from flac. Batch Converter won't apply RG after-the-fact, either.
                - Mark
                  • 46220
                  #23
                  Update 18th July
                  Decoder can stream from HTTP
                  (download as first message)
                    • 46220
                    #24
                    Update 24th November
                    Seeking now works correctly
