[Audio Info] Utility Codec
This topic is closed.
    • 46220
    A utility codec for dBpoweramp Music Converter (dMC) which extracts audio details and presents them either as a list, or a tab delimiter table (for pasting into a spreadsheet, such as Excel). Designed to extract details from 100's if not 1000's of files in one go, use with dBpoweramp Batch Converter to select all audio files with one click.
    Download:
    294 KB
    It is possible to extract (as well as others):
    File Name
    Length
    Channels
    Sample Rate (Hz)
    Sample Size
    Bit Rate (kbps)
    Size (Bytes)
    Uncompressed Size (Bytes)
    Compression (% of Original)
    Type
    Path
    Audio Quality
    Encoder
    Sample Count
    Gapless
    Atoms
    Encoder Settings
    Wave Header
    Channel Mapping
    Riff Chunks
    Protected
    Contains
    ID Tags, such as: Artist, Album, Title, Track, Genre, Year, Comment, Compilation, Tempo, Encoded by, Album Artist, Composer, Disc, AccurateRipResult, AccurateRipDiscID, ReplayGain, MPEG Version, MPEG Technical, ISRC, Rating
  • Stuart.Truman
    • Oct 2007
    Re: [Audio Info] Utility Codec
    Great Utility. Some suggestions/feedback:
    It would be nice to be able to select just the info you want to extract e.g accuraterip status and secure status.
    It would be nice if Tab separated is selected, that it changes the default file extension
    Currently, the save location defaults to the my music folder and is greyed out so you can't change it other than when you save the txt file.
    • barryl
      • 20
      Very useful.
      Some sort of configuration file to specify extra tags for future extensibility would be useful. (I'm not sure if you're displaying 'all' tags or if you have a built in list). This file could also be used as the tag selection list. This would be a great utility to search for annoying WM tags left over from a conversion.
        • 46220
        If you do it as a table for importing into excel, it is very easy to remvoe the columns not required.
        • chileboy
          • 96
          This is great.
          I'm starting to realize that, every time I have a need to complete some task, you've already provided for it (or are in the process of doing so).
          Thanks, Spoon!
          - Mark
          • musikal
            • Jan 2008
            Great utility
            The only thing I'd miss is the ability to have a comprehensive list for a complete volume (folder with sub-folders,...), or just I didn't manage to figure out how it could be done.
            I've been successful at having a compehensive list when final files were selected, but could not manage to have a selection of a folder or various folders.
            Thanks again for your great software and extensions
              • 46220
              Use batch converter to select the folder.
                • 46220
                Now Released.
