Drive unusable after first read
  • flips
    • Jan 2006
    • 93
    Hi!
    I have the same problem with both R11.5 and R12. I had a harddrive failure, and have now reinstalled OS and everything, same DVD drives as before, but now with new mainboard, CPU and memory. This time around I have trouble with dbPowerAmp CD Input that I did not have before:
    After the first time it accesses a CD/DVD in the drive, the drive is left unusable, I have to reboot to get the drive back (sometimes is actually disappears from Windows' list of available drive). This of course also give Explorer trouble everytime it tries to access My Computer ...
    Nero CD/DVD Speed does not have any trouble testing and measuring the drive's performance. I had another program I use for burning DVD's that does not work now. I have to burn the files it creates from Nero instead of directly as I did before.
    Any idea on what to check/how to proceed?
    flips
    Re: Drive unusable after first read
    Test using other rippers, if they are the same then replace CD Drive (possibly motherboard)?
      Double-check the connectors of the CD drive and motherboard, make sure the IDE/SATA cable is securely connected. Also, double-check the jumper settings on the CD drive.
      Can Windows access the CD drive fine? If you play the CD with Audio CD Input (a PowerPack feature), does the drive lock up? Does it lock up when you run Audio CD Input, or just when it starts converting?
      What OS are you using? Did you install the drivers for your motherboard?
      • flips
        • Jan 2006
        • 93
        EAC does not seem to have any trouble at all ... (Same with Nero 6.) The drive is the same as I used previously on my former mainboard ...
        • flips
          • Jan 2006
          • 93
          I double checked the connectors and jumpers and everything when installing the new motherboard. And since EAC/Nero etc. does not have trouble, I assume that's not the problem. (Or could dBPowerAMP be more "picky"?)
          I dBpowerAMP CD Ripper I have no trouble playing tracks from the Audio CD as long as it is recognized and everything. And the program recognizes the first CD ok, but when I eject that and inserts the same CD or another CD, it is not recognized. It actually makes both my DVD drives unusable until next reboot.
          As for the drivers, I installed all the drivers that came with the motherboard, and there is no devices not recognized to function properly in device manager. (No "!" or "x" marks on anything/any device.)
          I'm running r12 beta 2 now. When I installed r11.5 and later r12 after a full purge of everything in registry etc., accurate rip wanted more than one CD, "key discs", but after the first one, it complained that it did not have the permissions/right to read the CD drive -- as it was unavailable. So it is something in the way it accesses the drives, that makes the drives unavailable.
          I just discovered one interesting fact, though:
          When I remove one disc and insert another, it's unavailable, I'm returned to the insert disc/choose drive dialog. But if I click the "Options" button, the program starts working, and after half a minute or so, it now recognizes the CD. (So I have to do this between each CD.)
          I do get Inaccurate scores on CDs, though, but I'm not sure if that's related or not to the problems. (Nero found the drive to have full score on accuracy.) As long as the CDDB entry is not correct, maybe the AccurateRip db may be off as well ...
          Did that make more sense? Give you more hints to what might be wrong?
          flips
          The r12 interface/look and fell is very nice, btw!
          • bhoar
            • Sep 2006
            • 1173
            How are these drives connected?
            Motherboard IDE? Motherboard SATA? PCI Card IDE? PCI Card SATA?
            USB? Firewire? eSATA?
            If IDE, are they on the same channel (one master/one slave), or separate channels?
            -brendan
            • Bill41
              • Nov 2004
              • 56
              [QUOTE=flips]
              Try using "Refesh" button.
                Make sure you do not have the option checked 'prevent autorun on all cd drives' that would stop the system from seeing a new cd.
                • flips
                  • Jan 2006
                  • 93
                  The drives are connected to the motherboard's IDE controller, being master and slave (as there is only one IDE channel on my new motherboard). As for the refresh button, I have tried it, but I am returned to the "Insert Audio CD into"/select drive dialog.
                  The problem goes deeper. The drive is left unusable after I eject the first CD (which it recognizes automatically). And explorer.exe hangs if I then open My Computer. But hitting "options" fixes the problem until I eject the CD again ...
                  This option is not selected.
                  • bhoar
                    • Sep 2006
                    • 1173
                    Spoon - how about an option to log drive commands/responses to a file with timestamps? Perhaps skipping the larger data transactions (reads during ripping)?
                    Might help with debugging.
                    -brendan
                      Apart from time stamps, already done (enable debugging in dMC Configuration) - it is designed to find where crashes and locks occur.
                      • bhoar
                        • Sep 2006
                        • 1173
                        Perhaps flips can submit the logs, then, to see if the drive is returning any odd responses?
                        -brendan
                        • flips
                          • Jan 2006
                          • 93
                          I found a solution:
                          Options -> Communication:
                          "SCSI Pass Through (SPT)" was selected.
                          I changed that to:
                          "ASPI [Ahead Nero]", and now it seems to be working
                          Maybe WinXP has some trouble somehow, but then EAC and other apps should have problems, I thought ...
                          flips
                          • flips
                            • Jan 2006
                            • 93
                            + a quick question: The album art is not stored anywhere locally, or is it?
                              By default, the album-art is embedded in the file. There is an option to put the album art as a folder.jpg picture in the folder of the ripped music.
