Monkeys Audio and dMCr12beta
  • petriburg
    • 172
    I just installed the beta version of r12. On checking the configuration via start>all programs etc., I find a. No mention of "registered", although I installed it over r11.5 registererd, and b. Monkeys audio codec doesn't appear in the codec list, although it IS installed. (Everything is in the Illustrate folder, of course). Any comments, please?
    Re: Monkeys Audio and dMCr12beta
    Moved to Beta forum.
    Does Monkey's Audio show up in the list of files you can convert to?
    • petriburg
      • 172
      No, the only codecs which show up are:
      Codecs Installed
      Encoders (write)
      mp3 (Lame) Lame 3.97
      .mp3
      Test Conversion
      Wave Release 12 Beta 1
      .wav
      Decoders (read)
      CD Decoder Release 12 Beta 1
      .cda
      mp3 Decoder Release 12 Beta 1
      .m2a, .mp1, .mp2, .mp3, .mpa, .mpg, .mpga, .mpx
      Wave Decoder Release 12 Beta 1
      .wav
      Is this some limitation imposed by r12beta? I wouldn't have thought so. And what about the "registered" tag, which also doesn't show?
      Tony
        Did you install the Monkey's Audio codec on the dMC r12 download page? Because the one in Codec Central will not work.
        Also, I don't believe Spoon has implemented the whole Registered/Not registered thing for dMC r12 yet but I'm not sure.
        • petriburg
          • 172
          LtData (you must be due for promotion soon!)
          Your para 1 - I'm not sure - but I'll go back and check
          Your para 2 - Yes, that could well be, I think. At least Spoon has done a great job thus far ... deserves a big thank you from all of us - Tony
          • petriburg
            • 172
            Lt Data - just carried out those operations - everything now is OK. One of Spoon's notes about r12 states that registration is not yet implemented, so all's well. Thanks for your help - Tony
