How can i convert CONCERT DVD to audio with dmc
  • dman
    • Dec 2005
    id like to convert vob to audio with dmc
    Re: How can i convert CONCERT DVD to audio with dmc
    Sorry, you cannot do it as a straight conversion. You will need a dvd ripper program to actually extract the audio file for you, which you can after that convert using dMC..
    Or you play the dvd in whatever player you have while at the same time using dMC Auxiliary Input to record the audio as it is being played through your sound card.
    • gameplaya15143
      • Sep 2005
      • 276
      i would bet that the directshow plugin could do it... might not work all that great, but it could probably do it.
      but yea, use a dvd ripper and extract the audio tracks (probably ac3) then convert them to whatever you want.
