How do I extract an audio clip from a DVD movie?
  • Saramati
    • Aug 2004
    What do I need to do in order to copy an audio clip from a movie DVD---about 3 minutes worth, not the whole DVD audio. Is there some way to capture it as a stream as the DVD plays?
    Re: How do I extract an audio clip from a DVD movie?
    You will have to play it in a small window first of all.
    You can use dMC Auxiliary Input and record the audio from the sound card (use Stereo Mix or What U Hear as the input source for recording in Volume controls). Please chck in teh Faq section of the forum at http://forum.dbpoweramp.com/showthread.php?t=5362 on how to use dMC Auxiliary Input.
    There are other ways if you manage to save the video to your pc as an mpg file, then you can run it through other programs end extract the audio file.
