how do i defrag and what does 'rendering for DSP effects' do
  • neilthecellist
    • Dec 2004
    • 1288
    Originally posted by christinas
    You may also be due for a defragmentation of your hard disk.
    speaking of defragmentation.... what's the best defragmenter out there? The one that comes with Win XP Pro sucks. It leaves so many gaping holes = not good
    Originally posted by SPOON (da man)
    Check you are converting to the same frequency as the source audio, changing frequencies can be slower. Look out for an action: 'rendering for DSP effects' if you see this then more work is being does.
    what does 'rendering for DSP effects' do? I don't even see an option for that anywhere...:confused:
    Re: Conversions slower than they used to be
    Most people say Diskeeper is good. In fact, the XP built-in defragmenter uses a stripped down version of Diskeeper
    That's what the status window says when its applying DSP effects, mabye? I don't know, I've never used DSP effects
    • neilthecellist
      • Dec 2004
      • 1288
      exactly. stripped down. is there a GOOD defragmenter?
      also, why would DSP effects cause conversions to be slower?
        I think defragmenting has to be done by the Windows defrag program, probably not much choice there, though I may be wrong. Gaping holes are not a problem, many tiny little holes are a problem.
        DSP effects very definitely slow down the conversion process. The more effects you use and the more elaborate they are, the slower.
          There are third-party programs that defrag your hard-drive. And Neil: the full version of Diskeeper is normally regarded as one of the best degragmenter
          • adaywayne
            • Nov 2004
            • 383
            I love it....set it and forget it they say, and that seems to be true. I have even had it run whilst transferring audio from LP to CD or doing other audio projects such as burning a CD.. However, I don't recommend that (audio processing is veryy CPU iintensive) so I disable it before starting such projects.
              I have "Set It and Forget It" on screensaver mode. :D
