Register Power Pack
  • mailman
    • 14
    Register Power Pack
    I downloaded/installed Power Pack, then I registered it. Is there anything else I need to do (i.e. provide my order # online or within the program, etc.) in order for it to be registered and not a trial version? How do you distinguish registered from non-registered. Also, is there something I need to do to get the Register Power Pack icon to go away within the program? Thanks for a great product!
  • Wayne
    • Aug 2002
    • 1254
    Re: Register Power Pack???
    You should receive an email from Spoon containing a link to the registered version of the powerpack for download. Until this version is installed you will be using the non-registered version.
    Wayne
    • mailman
      • 14
      Great, that was simple!! Thanks again!!
