How To Disable Re-Rip?
  • starvinmarvin
    • Mar 2013
    • 18
    Sometimes re-ripping a track on a CD takes forever. Sometimes I'm willing to accept that the track isn't perfect.
    So, how do I disable re-rip? I can't see an option for that in the Configure page.
    My version of dBPoweramp is Release 15.3. Thanks for your help.
    • 45598
    Re: How To Disable Re-Rip?
    Use Burst instead of secure ripping, re-rips are a part of secure ripping.
    • starvinmarvin
      • Mar 2013
      • 18
      Thanks very much!
      In the Options I also noticed that re-rip can be limited to a chosen number of frames, and can also be time-limited. Have set the time limit to 3 minutes which isn't too long a time to wait, I suppose. If that proves unsatisfactory then Burst will be the next choice. Thanks again.
