How to fix missing ID3 tags for songs ripped in iTunes?
  • rfan
    • Feb 2021
    Hi new user here - apologies if this has been answered elsewhere, I haven't found it in the forums.
    Is it possible to add missing metadata automatically?
    A few years ago I ripped all my music to iTunes Lossless (ALAC) format. Unfortunately I got rid of most of the CDs. Now I realize what a mistake this was and I'm trying to fix the mess. I would like to use an MPD player but it requires ID3 tags that are missing from the ALAC files.
    In PerfectTunes I can edit sort tags manually but this would take years. I also tried using Audio Converter to convert some ALAC files to FLAC, but this didn't add the missing metadata, specifically id3-tags albumartist, artistsort, & albumartistsort are absent and the player I'm trying to use requires these tags.
    Basically I'd like to end up with a library of lossless music files (ideally FLAC) that have standardized metadata that's widely compatible, not limited to iTunes / Apple Music.
    Thanks for any tips / suggestions on how to approach this.
    • 46370
    Re: How to fix missing ID3 tags for songs ripped in iTunes?
    Sorry we do not have anything which can do this.
    • rfan
      • Feb 2021
      OK, thank you. A follow-up question:
      Using PerfectTunes I added Artist Sort, Album Artist Sort, and Album Sort tags to several albums. But when I view the files' metadata, sort tags are null. For example:
      songsForArtistAndOrAlbum(artist: Ahmad Jamal, album: The Essence Part 1 file='Ahmad Jamal/The Essence, Part 1/01 Ahmad Jamal - Flight.flac' title='Flight', artist='Ahmad Jamal', albumartist='', album='The Essence Part 1', year='1995', sortartist='', sortalbum='', sortalbumartist='', performer='', composer='Ahmad Jamal'
      Are these sort tags not supported on flac files?
        Those sort tags are supported in flac files.
