Asset will appear on your UPnP control point as Asset UPnP: [Computer Name], select A
  • AaRON2020
    • Aug 2020
    Have just insta;led but canoot activate, have registered, paid etc, on the siye it says "Asset will appear on your UPnP control point as Asset UPnP: [Computer Name], select Asset to browse for audio tracks:.... where is this UPnp control point from which I can "select Asset to browse for audio tracks:, ...I selecy asset PHup but when does it browes tracks??many thanks if you can help, cheeers
    • 45581
    Re: Asset will appear on your UPnP control point as Asset UPnP: [Computer Name], sele
    Asset is a UPnP server, it does not come with the browsing software, as normally your player will have that. You can install this control point for Windows:
    Asset Control (a UPnP / DLNA control point) is billed as the control point you have been waiting for . In UPnP there are: Server / Control Point / Renderer, where the Server catalogues tracks, Control Point creates playlists from the Server and controls the Renderer (player), all 3 elements of UPnP could reside on the same
