Select multiple folders and have [audio info] export data of all files incl folder?
  • belinea2010
    • May 2020
    • 17
    I am using [audio info] codec to read and export audio file tags to a text file which I them import into a Excel spreadsheet.
    This works fine if I am inside a single folder and then select all of the files I want the tag data for but my files are arranged inside folders (one folder per album). Each folder is named Artist - Album Title.
    Can I select multiple folders and have [audio info] codec read the tags of each file in the folder and export the data.
    It would be even better if [Audio info] would also include the folder name where each file is located?
    Thank you for such a brilliant program that can do so much.
    • 4015
    Re: Select multiple folders and have [audio info] export data of all files incl folde
    For multiple files/folders, you can use dBpoweramp Batch Converter
    • belinea2010
      • May 2020
      • 17
      Great thank you
      but what about the folder name/file location?
        • 44044
        Audio info has both path and filename (check both boxes, comma separated and extensive)
        • belinea2010
          • May 2020
          • 17
          Thank you mville & Spoon.
          I really appreciate your help and dbpoweramp is an amazing program.
