Is both same quality
  • saii
    • Aug 2019
    • 17
    I HAVE A PROBLEM WITH ONE DISC RE RIP FRAMES ABOUT 14000.
    SO I MADE IMG FILE OF AUDIO CD AND BURNT TO BLANK CD
    NOW CD RIPPED PERFECTLY WITH OUT RE RIP FRAMES THROUGH BURNED CD
    Any change In audio quality of burned cd and original cd
    • 1897
    Re: Is both same quality
    Did you get an accurate rip for the re rip of the burned CD?
      • 45826
      If your first rip had errors, the 2nd rip would have the same errors, just that the cd drive cannot detect them.
      • saii
        • Aug 2019
        • 17
        Even original cd i got secure rip and burned cd also secure rip
        same crc
        • saii
          • Aug 2019
          • 17
          For same original cd and Burned cd got secure rip and same crc
          My audio cd is telugu
          Since telugu cds have less data base in accurate data base
          That is why secure for me
            • 1897
            Hey saii,
            so from my point of view you have a good chance for a good rip and it is the best you can get out of that CD, even though it isn't proofed by the accurate rip database.
            I have some indian or indian influenced music too, but those CDs are quiet popular so those could by proffed by accurate rip.
