Uniform Audio Level confusion
  • DanTurner
    • Mar 2019
    I've gotten a great thumb-drive now full of some outstandingly good music thanks to DBPoweramp.
    However....the audio levels appear to be something that I failed to take into consideration as the volume varies considerably while in playback.
    What did I do wrong....and is there a really easy way to bring resolve the issue?
    Thanks!!
    • 6189
    Re: Uniform Audio Level confusion
    Thanks!!
    use dbpa to batch convert to the Replay Gain Utility DSP. This will add Replay Gain tags, and then any ReplayGain-aware player will automatically adjust volume of tracks to try to equalize. Can't recall, but you may need to install the replay gain DSP from "Codec Central"
    p.s. none of this changes the audio in the tracks....it simply adds special tags.
      • 46220
      If your player is not replaygain aware you would have to apply the gain, with a volume normalize, as this changes the data keep copies of the originals.
      • DanTurner
        • Mar 2019
        Thank you very much!
        I'll give it a go this weekend and report back same! Again..thank you for the response!
        • DanTurner
          • Mar 2019
          Good info for a heads up. Everything is copied...ready for the batch convert. I'll send back my results in a day or so. Thank you!!
          • CiXel
            • 18
            I don't see a way with the replaygain 'codec' to apply the gain.
            As I recall a long time ago there was a codec that would just allow you to process DSP (and thus use the Replaygain (Apply) DSP)
            What's the best way to 'Apply' replaygain to a group of tracks without going through a re-conversion?
              • 46220
              Use the Volume Normalize DSP effect, this calculates replaygain and applies in one.
              • CiXel
                • 18
                Right, there are some other neat options in there. I'll explore that more over straight replaygain.
                I thought there used to be a codec that allowed you to just apply DSP to the given file (MP3 to MP3 or FLAC to FLAC)
                Perhaps I was thinking MP3gain instead.
                  • 46220
                  There is Replaygain (Apply) DSP effect, however the source file needs to have replaygain ID Tags.
