Does Bit rate matter in FLAC constant or variable ?
  • GQ72
    • Jun 2018
    • 11
    ...new to FLAC and am doing some trial and error, still experimenting
    I started ripping to FLAC 'uncompressed' but found I do not need to do this (data is still losseless no matter which encoding level is selected) I then did a dozen using Level 8 (highest) which is much smaller file size then the uncompressed.
    I then compared an album that I had done in both levels and noticed quite a significant difference in each one's Bit Rate
    The uncompressed ranged from 1412kbps to 1430kbps ... these look very similar to what I used to get with WAV files
    The Level 8 Bit Rates ranged from 517kbps to 1035kbps ... not sure why the huge swing other than it being variable (VBR) and not constant (CBR)
    my questions...
    should I be doing these in CBR if there is a setting I need to change? ... I used to rip everything to MP3 320 CBR
    is there ANY AUDIBLE difference in the different bit rates of any kind? ... I do not know much about this stuff just want it done the right way lol to overall perfection ... i.e., I want the exact same quality sound I get from my SONY multi-disk changer to come out of my PC and media player of choice (still need to choose what will work best, looking at mediamonkey ... is there a forum topic for various media players here)
    reviewing the two sets of data on the same album I just found a very odd occurence....
    track *3 in the uncompressed level is the highest bit rate 1430kbps @ 11,023 KB file size ... in the level 8 it is the smallest bit rate of the bunch at 517 kbps @ 4,118 KB in file size
    -- What is going on here? it does not make much sense ... does anybody have a clue or some valuable helpful explanation
    thanks
    Re: Does Bit rate matter in FLAC constant or variable ?
    FLAC is lossless in all modes, that means the decoded audio is identical for each encoding method employed.
