How do I change setting of Metadata mouse over info window
  • RexLaundret
    • Aug 2016
    Hi all, I've just signed up to ask this question, I've used DBPoweramp since R12. But since I upgraded to Windows 7 from XP and more recently to Windows 10 x64. I'm not been able to see all the data I add to my mp3 files metadata. I tried to configured dbpoweramp pop info setting using the dbpoweramp configuration window via all apps on the start menu. In the music converter tab, enable pop-up info tips advanced window. I increased the maximum line length to double the default, same went for the maximum line count. But windows seems to override whatever I enter and only allows 25 lines max showing this character "%" halfway through the last line of the metadata. Is there a way to stop windows limiting the size of the pop-up information window in windows file explorer
    cheers
