Batch Converter/Win10 Context Help
  • KDIV
    • Jul 2016
    How do I add dbPowerAmp Batch Converter added to Win10 (right-click) context help menu?
    In side of Batch Converter, I could find nothing about settings, preferences, options, etc.
    As well, does anyone know about updates? Mahalo
    • 1752
    Re: Batch Converter/Win10 Context Help
    I can only answer for R14/R15: open "Configure dBpoweramp", click on the register "Music converter" and check the settings. For updates have a look at the boards "news & updates" and "Test Upcoming Releases".
      • 44047
      For R16 run dBpoweramp Control Centre and select 'Advanced Settings'
      • KDIV
        • Jul 2016
        Mahalo, I have v15.x, I noticed after posting, I typically develop my applications whereas settings are contained within the application never seen a separate .exe to run settings before. Have you tried v16?
