Edit ID Tags: Embed Album Art Not Working (How to fix?)
  • Wickedfox
    • Oct 2025
    • 31
    I have it so edit ID Tags option appears when I right click a audio file. Even though I select a cover and click on ok, it doesn't show up when I play the file. This applies to wav, flac, mp3, and ogg. Some works but 99% of them don't. When i go into the setting again, the art isnt even there. How do I fix this?
    • 46226
    Which version do you have? on which platform?
    • Wickedfox
      • Oct 2025
      • 31
      Windows 11
      release 2024-11-04
      • Wickedfox
        • Oct 2025
        • 31
        would I have to use perfect tunes instead?
        • Wickedfox
          • Oct 2025
          • 31
          looks like the wav files im trying to embed art into has riff tagging. Will perfect tunes convert it to id3 tagging?
          • Wickedfox
            • Oct 2025
            • 31
            or do I have to use mp3tag which I tried and it converted riff to id3, but my question is does it affect the sound quality at all when I convert it to a different tagging system?
              • 46226
              It is an option (control center >> codec options), however if the wave file already has a LIST tag, then an id3 tag is not created, unless you convert all your wave files to [ID Tag Update] which will create the id3 tag.
              • Wickedfox
                • Oct 2025
                • 31
                is this in perfect tunes or dbpoweramp control center? I changed the tag creation for wav from id3 to default (LIST & ID3). Im asking cause I don't have perfect tunes and want to know before buying it
                  • 46226
                  No, normal dBpoweramp.
                  • Wickedfox
                    • Oct 2025
                    • 31
                    got it to work! Though on certain mp3 files it doesn't embed the album art
                      • 46226
                      If they have an ID3v1 tag, then that cannot have album art, you would have to do the same for those files to get to ID3v2.3
                      • Wickedfox
                        • Oct 2025
                        • 31
                        the mp3 are from a youtube to mp3 downloader. Still doesn't show up even though it's embedded in the file. It's fine as I only have a handful of mp3s. As long I got it to work with wav, im happy : )
                        • Wickedfox
                          • Oct 2025
                          • 31
                          Oh! And adding tags to wav through this method won't effect the files audio quality right? Just the way its tagged?
                          • Wickedfox
                            • Oct 2025
                            • 31
                            Talking about the right click context menu, edit Tags method
                              • 46226
                              Does not change quality.
