.RAW audio file conversion with DB Power Amp
  • norke
    • Jul 2015
    Hi everyone !
    I'm trying to convert .raw files with dbpower amp. Is it possible ?
    I found a codec : http://www.dbpoweramp.com/legacy/codec-central-raw.htm
    But it doesn't seem to work...
    Thanks !!
    • 46225
    Re: .RAW audio file conversion with DB Power Amp
    We no longer have this codec for a recent version of dBpoweramp, sorry.
    • norke
      • Jul 2015
      Until wich version does it works ?
        • 46225
        R11, about 10 years old.
        • norke
          • Jul 2015
          So you're saying R11 is able to encode and decode .raw files ?
            • 46225
            Only decode.
            • norke
              • Jul 2015
              Oh ok, thanks a lot !
