Uninstall 32-bit after updating to 64-bit?
  • Darryl R
    • Jul 2014
    • 101
    I recently upgraded to 15.1 (64-bit) from 14 (32-bit), and it appears the install left most of the old files intact. I'd like to remove the old files, and only have 15.1, but I know with some software you can get burned removing earlier versions after installing a later, as there may be dependencies.
    What is the best way to do this? I'm thinking uninstall all, and only put 15.1/64-bit, but will this work, or are there dependencies on the old files?
    Spoon documented scenarios where 32-bit is needed (e.g. CD Writer I believe), but those are not applicable to me.
    Re: Uninstall 32-bit after updating to 64-bit?
    Run this:
    Then reinstall 64 bit
    • Darryl R
      • Jul 2014
      • 101
      I uninstalled all programs via Control Panel, then ran your clean program, and reinstalled 15.1 as directed. Thanks!
