Right Click Edit ID Tag - Disappeared
  • hatfield
    • Jan 2008
    • 9
    Since upgrading to 15 I no longer have the option to edit ID tags when right clicking over a track. I checked in configuration and I do have the box checked so I should be able to do this. Running Windows 8 on a PC. Any suggestions would be appreciated. Thanks!
    Re: Right Click Edit ID Tag - Disappeared
    For which file type?
    • hatfield
      • Jan 2008
      • 9
      FLAC and mp3. They are the only files I've worked with since the upgrade. I'll try to figure it out some more on my side and will post back if I figure it out. Thanks for trying to help me out Spoon!!
      I just noticed that even my right click option to convert a file no longer shows up. The batch convert for the folder is there when I right click the folder but if I right click over the mp3 file I no longer have an option to convert the file.
      • hatfield
        • Jan 2008
        • 9
        I uninstalled everything, reinstalled and now it's fine. Thanks Spoon! Looking forward to checking out the upgrade.
