Audio Conversion Engine not converting
  • Grahamuk2013
    • Jul 2013
    I have downloaded the trial of Audio Conversion Engine. I have set the source folder and destination folder to output to but it doesn't seem to do anything even though automatic polling is enabled. I am using Windows 8 if that makes any difference.
    Graham
  • daren
    • 153
    Re: Audio Conversion Engine not converting
    Hi Graham,
    Do the logfiles give an indication of what the problem could be?
    The logfiles are typically saved in the "c:\program files\illustrate\dbpoweramp\logs" directory, unless you have setup a different directory for this.
    You might need to set the logging level to debug to drill down to the root cause...
    Best regards,
    Daren.
    • ashi12
      • Jul 2013
      I have also have the same problem when downloaded the trail of Audio conversion Engine. How i sort out this problem. please guide me.
