how do i rip a 32 bit auio cd using dbpoweramp
  • Pgla
    Can anyone please tell me how i rip a 32 bit audio cd using dbpowerap ripper, into the flac uncompress losless format?
    • 45659
    Re: how do i rip a 32 bit auio cd using dbpoweramp
    All Audio CDs are 16 bit, there is not such thing as a 32 bit audio cd.
    • Pgla
      Hello and thanks,
      This came up because I was shopping on line and found 24 bit ad 32 bit audio cd's on amazon, as well as hybrid.
      In your tool thier is an option hdcd, when would a user choose that option when ripping a cd into flac format.
      thanks
      • Razgo
        • 2532
        good question, i am not familiar with it myself though. we can see what HDCD is older technology not as common anymore http://en.wikipedia.org/wiki/High_De...atible_Digital
        In 2008, with HDCD in decline, it was reported that conventional CDs produce a quality of sound that is now equal to or even superior to an HDCD without the cumbersome need for special encoding
        So you would use the DSP effect option HDCD's as listed here if you have a HDCD http://www.dbpoweramp.com/cd-ripper.htm
        DSP digital signal processing, effects which can be applied whilst ripping, many effects straight from pro-audio with internal 32 bit floating point processing, completeDSP effect listing. HDCD's can be decoded to 24 bit with DSP Effects.
        • dbfan
          • Jan 2011
          • 937
          If you read the small print you will see the cds were mastered from 32 bit, all cds except hdcd are 16 bit.
          • Razgo
            • 2532
            and a thread on the subject here if you haevn't already seen it. http://forum.dbpoweramp.com/showthre...Best-practices
            • wordpresshost
              • Feb 2013
              just destroy all bad.
              oh I have same problem I try recovery of this.:smile2:
