streaming radio with more than 32kbs doesn't work
  • geraldp
    • Jan 2013
    Hi, I just installed the full Version off asset upnp, when i try to listen Radio Station with more than 32 Kbs streaming doesn't Start. Station with 32kbs are working fine. What can I do ?
    Thx
    Gerald
    Re: streaming radio with more than 32kbs doesn't work
    How many stations have you tried? normally there are a bunch which are incorrectly configured.
    • geraldp
      • Jan 2013
      I've tried all local stations in Austria and around 50% doesn't work. I have verified and the issue is not related to the Kbps, nevertheless if i play this station via stream box from project, the station are working fine.
