How Do I Extract artwork from flac flie?
  • FMNY
    • Oct 2010
    • 50
    Can I extract the cover artwork from a flac file? One of my own beautifully scanned Folder.jpg files got overwritten by a crappy internet cover scan when I was scanning CD-2 of a set. I'd like to get my much nicer file back from within my flac files if I can so I use it instead of the low res internet version dbpoweramp found for me. I know how to add the artwork to a flac file but I don't see how to extract it back out.
    • 46029
    Re: How Do I Extract artwork from flac flie?
    Install the Utility Codec [ID Tag Update] and covert to ID Tag update with only the Export Folder.jpg option set.
    • FMNY
      • Oct 2010
      • 50
      Thanks. Worked perfectly.
      • bling
        • Mar 2012
        heyy thanks i was looking for it too
        • stefan
          • Feb 2012
          Thanks!
          • jberg
            • Feb 2022
            A little more info for anyone extracting album art with dbPoweramp:
            Start Batch Converter
            Choose some files or folders
            Click "Convert"
            In the dialog box Choose
            Encoding: ID Tag Update
            Then to tab "Manipulation" and scroll down to "Album art" and choose "Export to" to be "Folder.jpg" or whatever option you want.
            Click "Convert" down to the right and it should extract album arts for all selected files or folders.
            • Whoopmeister
              • Aug 2018
              • 13
              Click "Convert"
              How can I export all artwork from a FLAC? This method only extracts the first embedded image. I am trying to grab front and back covers, sleeves, etc.
                • 46029
                It is not possible sorry.
                • andrehendrik
                  • Jan 2023
                  Click "Convert"
                  I'm trying to convert my ALAC files to FLAC while keeping/transferring album art. After starting Batch Converter and choosing an album/folder, I don't see anything marked "Dialog Box" or any of the subsequent options described above; I do see the DSP effects to which I added Folder.jpeg Preserve, but it doesn't seem to work for my particulars -- I must be doing something wrong and if you could point in me in the right direction I'd really appreciate it. Thanks.
                    • 46029
                    First check your ALAC files contains album art, right click on one and Edit ID Tags. If it does not show then the album art is kept in iTunes and not the files.
                    dBpoweramp by default will transfer the album art from one file to another.
