Dynamic output naming
  • coiner
    • Nov 2011
    is it possible to rename output files with ascending numbers automatically?
    E.g. like this:
    01.mp3
    02.mp3
    03.mp3
    How could it work?
    Thanks in advance.
    • 45601
    Re: Dynamic output naming
    use [unique] as the naming for the filename
    • coiner
      • Nov 2011
      This was exactly what I needed to know.
      Thanks!
      • coiner
        • Nov 2011
        Have another question:
        Is there a way to reset the counter?
        Do I have to delete a certain file or is there a setting which defines with which number it starts?
        Thanks again.
          • 45601
          It is in the registry:
          HCKU\Software\Illustrate\
          • coiner
            • Nov 2011
            Jep, found it. Thank you very much, makes thing a lot easier.
            Most of you will already know, but for anyone who doesn't and has the desire to set the counter back:
            1. open Notepad
            2. copy & paste in
            Code:
            Windows Registry Editor Version 5.00
            [HKEY_CURRENT_USER\Software\Illustrate\dBpoweramp]
            "Unique"=dword:00000000
            3. save as "whatever_name.reg"
            Every time you want to set the counter back, just double-click "whatever_name.reg"
