How Do I Split a File Either Pre or Post Rip
  • musicmafia
    • Jan 2008
    • 51
    I have a CD of live music that has 5 songs that show up in CD Ripper as 1 file. Is there a way to seperate them by each song? If not and I proceed to rip as 1 file to FLAC, can I do it post rip? If not and I convert to WMA or MP3 what is the easiest program to do it then? Thanks
  • BrodyBoy
    • Sep 2011
    • 780
    Re: How Do I Split a File Either Pre or Post Rip
    You need to use an audio editor to break up what is, essentially, one large audio file.
    For these sorts of tasks, I use a program called Audacity. There's no quick and "easy" way to do what you want. You have to spend some time manually identifying each split, creating a separate file for each part, adding fades, etc. It's kind of tedious, but you can do it if you really need those as separate files. That's what audio editors are for....but dBpoweramp isn't an audio editor.
