Normalize audio
  • Giorgio
    • May 2006
    • 73
    Normalize audio
    Hello to everybody !!
    I have ripped all my cds on Flac format and I use Linn Akurate to listen my music.
    So I have a big library with all the tracks I like.
    Because the volume is so different on all the tracks, I would like to normalize all the tracks on this library without having any loss on the quality of the file (I like the music on the highest quality).
    My question is: what is the best program to use ? and what is the best settings for my use (listen at the same volum level various tracks ripped from several different cds).
    Do I have to make a copy of this library before I make any normalize or it is not necessary (is possible to go back to the original volume files ?)
    I wait your suggestions !!
    Thank youuuuuuuuuu :supersmil
    • 46198
    Re: Normalize audio
    If you use AssetUPnP then it is fairly easy, run your collection through dBpoweramp (Batch Convert whole collection) >> [Replay Gain] codec (you can find in codec central above). Then set Asset to stream FLAC 'as Wav' with the ReplayGain options set (24 bit).
    • Giorgio
      • May 2006
      • 73
      Re: Normalize audio
      Hello Spoon,
      I have all my music on my Nas and I'm not practic with AssetUPnP.
      Is there a way more easy to normalize these tracks without AssetUPnP?
      Concerning the 24 bit setting, it is ok also if the track is 16 bit ?
        • 46198
        Re: Normalize audio
        You increase the bitdepth from 16 bit to 24 to counter the possible loss of audio quality if the volume is reduced in a track (normalization can turn the volume up or down).
        If you are not using asset you have to create a 2nd copy of your library then convert it >> FLAC >> FLAC (in new location) with the DSP effects 'Bit Depth to 24 bit' and 'Volume Normalize set to ReplayGain'
        • Giorgio
          • May 2006
          • 73
          Re: Normalize audio
          Sorry Spoon,
          may be I understand now . . . AssetUPnP is it software like Songbook '11 ?
          If so I can use this instead of my Songbook and I have no more volume problems ?
            • 46198
            Re: Normalize audio
            Asset UPnP is the server:
            • Giorgio
              • May 2006
              • 73
              Re: Normalize audio
              So Spoon, ASSET should be a server on the web, while I have a Nas and I use Songbook to listen this music on the Nas. Am I right ?
                • 46198
                Re: Normalize audio
                Asset is a server which either runs on your PC, or a special NAS (Windows Home Server based)
                • Giorgio
                  • May 2006
                  • 73
                  Re: Normalize audio
                  Uhmm . . . so Asset is not hardware (like Nas or external disk) but the disk inside my pc can be used like a server if I use Asset . . . is it correct ?
                  Not easy, I'm trying to understand but I have difficulties . . .
                    • 46198
                    Re: Normalize audio
                    Yes, but it can also be hardware:
                    • Giorgio
                      • May 2006
                      • 73
                      Re: Normalize audio
                      Great Spoon !!!!!
                      That's music to my ears . . . finally I found a way more clear . . . . .
                      Last 2 questions:
                      - concerning the 24 bit setting it is ok this setting even if I have several 16 bit tracks and just few 24 bit ?
                      - concerning ipod or iphone does exist a way to normalize and listen my music on these devices ?
                      Thank youuuuu
                        • 46198
                        Re: Normalize audio
                        Yes
                        Yes - plug player which is a UPnP controller and player
                        • Giorgio
                          • May 2006
                          • 73
                          Re: Normalize audio
                          Hello Spoon !!
                          hope the map in my head is correct:
                          - I can use codec Replay Gain (that insert the information on the meta tag) to normalize my tracks
                          - I buy AssetNAS and AssetUPnP (which will support Replay Gain)
                          Now, do I have to continue to use Songbook 11 to listen to my devices Linn (I have Akurate, Magic and Sekrit) ? Or the Plug player that can work on iphone/ipod/ipad and support Replay Gain ?
                          Await your precious helppp, :smile2:
                          • Giorgio
                            • May 2006
                            • 73
                            Re: Normalize audio
                            Hello Spoon !!
                            And also, during my summer holidays if I'm not connected to any Nas but I have all the music saved on my Iphone, Replay Gain work on my Iphone or not ?
                            Await your very very precious helppp,
                            • Giorgio
                              • May 2006
                              • 73
                              Re: Normalize audio
                              Hello To Everybody !!
                              I need your help . . . to my last message . . .
                              Thank youuu so much
